Help with getting more sound!
Old Oct 26, 2015 | 10:57 PM
Firebat's Avatar
Firebat
Default Help with getting more sound!
Hi all, recently picked up a 2015 IS250 F-Sport AWD and installed a Takeda intake and F-Sport exhaust. I've been enjoying this setup a lot however I'm starting to want some more aggressive sound. I find with this setup the sound is a little too quiet (I want to turn heads!).
I was thinking about doing a resonator delete or a secondary cat delete or maybe both. Any opinions on the best route to go?
Thanks a lot!
Old Oct 27, 2015 | 08:27 AM
ddvette9's Avatar
ddvette9
Buy the Invidia midpipe. Quick bolt on part that will increase the sound of your exhaust.
Old Oct 27, 2015 | 08:54 AM
Firebat's Avatar
Firebat
Does the Invidia midpipe fit on AWD? What's the price range I should expect for one of those?
Old Oct 27, 2015 | 03:36 PM
cp2's Avatar
cp2
Veteran: Air Force
baseball cards in the wheel spokes
Old Nov 12, 2015 | 08:54 AM
YoungRider's Avatar
YoungRider
Unfortunately Invidia's midpipe does not fit the Awd....made only for the Rwd model although It can be altered to fit. One of the guys here had it tweaked at a local muffler shop and seemed to work out.
I'm stuck in the same boat here trying to find a midpipe for mines as well.
Old Nov 13, 2015 | 10:19 AM
Swacer's Avatar
Swacer
The fsport exhaust is only an axle back, so it leaves a lot to be desired. You could go with a full cat back exhaust, which would increase your overall volume.
I personally wouldn't bother with a midpipe on a small displacement 6 line the IS250, it will rasp and those "heads" you want to turn, will be people not impressed.
Old Nov 13, 2015 | 01:10 PM
ddvette9's Avatar
ddvette9
That's incorrect. I have an is250 with tanabe axle back and invidia midpipe and rasp is little to nonexistent. If it rasps its in 1st gear only during the last 1,000 rpm, maybe.
If you have an is250 and want more sound I'd choose f sport exhaust, tanabe exhaust or joe z exhaust with a midpipe. Those mufflers are deeper and will help limit rasp.
m2timesss
Dec 4, 2018 03:10 PM
Jaypmanuel
Performance
Oct 9, 2018 09:36 AM
chuongzzz
Performance
May 29, 2015 09:21 PM
rohanstar
Jan 6, 2014 10:24 AM
Emilkohan
Oct 28, 2012 12:48 PM
