roots blown gs430
Old Jun 13, 2016 | 09:38 AM
  #106
sakataj's Avatar
sakataj
Originally Posted by badblackgs
dyno results print out.
i forget, do you have headers, intake, exhaust? if not all 3 of those will add to much nicer #'s
Old Jun 13, 2016 | 08:37 PM
  #107
badblackgs's Avatar
badblackgs
Originally Posted by Zoolander
You're still using an auto tranny, yes?
yes, that is why I'm going to install an upgraded valve body.
Old Jun 13, 2016 | 08:42 PM
  #108
badblackgs's Avatar
badblackgs
yes I have headers, not sure what you mean by "intake" since the car is supercharged, and yes I have 2 1/2 inch exhaust. At first I was surprised by the numbers but than thought about it and looked into what factory gs430's make at the wheels (240). I'd say that 330 to the wheels is a very nice jump in power. And thats only five psi. how much psi does it take for a 2jzgte to make 330 to the wheels? If you've followed any of my threads I'm sure your aware that I don't stop. More will probably follow soon.
Old Jun 13, 2016 | 11:44 PM
  #109
Zoolander's Avatar
Zoolander
I'm more interested in how that tranny holds up. I'd love to see somebody make them stronger in a simple way.
Old Jun 14, 2016 | 12:07 AM
  #110
clos430's Avatar
clos430
What exactly do they do to the valve body when you "Upgrade the valve body" ?
Old Jun 14, 2016 | 05:17 PM
  #111
Zoolander's Avatar
Zoolander
I know Swift offers a valve body upgrade but you send them one to modify.
Old Jun 15, 2016 | 11:57 AM
  #112
sakataj's Avatar
sakataj
what brand headers? i dunno..... wasnt really thinking although you could put a SRT inline on that and probably get some HP. build a head and opening the head up would also free a lot of power
either way i would take 330 to the wheels
Old Jun 16, 2016 | 06:08 AM
  #113
GSJake's Avatar
GSJake
CL Folding 200,000
The process is to enlarge the passages of the valve body where the transmission fluid flows.
This only firms up your shift. Does not help with reliability when more power is introduced.
From what I have read its the synchro gears\rings that will give out when you have right around 400\450 HP.
TSI Jeff and TT pimp have some knowledge of the limits of the a650.
Old Jun 16, 2016 | 06:10 AM
  #114
GSJake's Avatar
GSJake
CL Folding 200,000
I agree Brian.. I think that would be enough to make this car a completely fun daily!
Thanks for your contribution badbalckgs!!
Old Jun 16, 2016 | 03:42 PM
  #115
badblackgs's Avatar
badblackgs
I'm glad to be apart of this community.
Old Jun 18, 2016 | 06:08 PM
  #116
Rock-a-Lex's Avatar
Rock-a-Lex
Agreed. He's been a huge help to me. Giving advice countless times! Thank you
Old Jun 22, 2016 | 03:16 PM
  #117
Cranix's Avatar
Cranix
Great build badblackgs!! Your thread is always on my list to read. I have a stock 430 with suspension mods. I recently had a fuel evap check engine code pop up. Found a soft hose unhooked from a hard line that goes back to the charcoal canister. That made me think of your build. If you are running boost wouldn't that jack up your evap system, since it works off of vacuum?
Old Jun 22, 2016 | 07:45 PM
  #118
badblackgs's Avatar
badblackgs
the evap lines are connect to the engine vacuum which is after the throttle body. so in my case I use the vacuum ports that come built into the supercharger. no issues. if your evap line is coming off over on the drivers side where the rubber goes onto the metal hard line, than your driv. side engine mount is bad and allowing the engine to lift up and yank that hose off.
Old Jun 22, 2016 | 07:56 PM
  #119
bigz187's Avatar
bigz187
Agreed, I'm curious to see how everything in setup
Old Jun 23, 2016 | 06:58 AM
  #120
GSJake's Avatar
GSJake
CL Folding 200,000
Much more complicated than that.
I know.. I was giving the ELI5 explanation.
On what transmission?
A650e
