Main seal leak.
Old Mar 6, 2003 | 02:39 PM
AROD's Avatar
AROD
Default Main seal leak.
I just found out my main seal has a leak. $750 to fix it . How long can I go before I really have to get it done? I know it has to get done but is it a real get done now deal or wait tell it get worse?
Old Mar 6, 2003 | 02:59 PM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
I had a rear main seal leak in one of my old Pontiacs. Tried to get it fixed, but it never took for long.
Ended up carrying a gallon of oil in the car and checked it every couple of days. As long as you don't let your oil level get low for an extended period, you'll probably be OK. That is, if you don't mind the little clouds of smoke and smell of burning oil you'll get when you roll up to a stoplight when the engine is hot. Just think of it as a mini-James Bond device and you'll be cool.
Old Mar 6, 2003 | 03:31 PM
redgs4's Avatar
redgs4
That sucks. My main seal started leaking at 42K miles and was replaced under warranty. Have you shopped around for prices? I would not leave something like that for long as a small problem now could be a much larger problem later.
Old Mar 6, 2003 | 07:08 PM
Wow, that sounds bad... REAL dumb question (like that's ever stopped me before) - is the main seal in the engine or in the transmission or someplace else?
AROD and redgs4 - I see you have a GS300 and GS400 respectively so I guess the problem isn't model specific.
Old Mar 6, 2003 | 10:14 PM
GSquicksilver's Avatar
GSquicksilver
my LS400 is leaking from the main seal too i think. do you guys have the engine oil leaking where the tranny connects to the engine? is that what u mean by the main seal?
Old Mar 7, 2003 | 06:11 AM
tomtnc's Avatar
tomtnc
Originally posted by bitkahuna
Wow, that sounds bad... REAL dumb question (like that's ever stopped me before) - is the main seal in the engine or in the transmission or someplace else?.
Located at the back of the engine block dynamically sealing the spinning crankshaft.
Old Mar 8, 2003 | 11:20 PM
AROD's Avatar
AROD
Thanks for the reply. Yeah it's right there where the two meet. I guess I'll take the hit and get it done.
Thanks again
PanicUnit
Sep 16, 2023 05:06 PM
Jvgs300
May 11, 2017 01:33 PM
ES300MM
Jul 9, 2014 07:02 AM
xDunksNjsX
May 24, 2012 03:55 PM
0nePutt
Maintenance
Oct 25, 2009 02:17 AM
