Optimize 1/4 times?
Old May 7, 2014 | 03:42 PM
specie's Avatar
specie
Default Optimize 1/4 times?
I'm about to take the car to drag strip. First time with an auto. Searched a couple threads and these are the recommendations:
-1500-2k rpm launch (235/55/19 Michelin PSS with about 27-32psi)
- traction control off ('06 so some funky stuff with the pedal)
- keep in drive with normal mode
- left foot on brake and smash gas
Missing anything or any other suggestions?
Old May 7, 2014 | 04:07 PM
idoke1's Avatar
idoke1
Right on the money. Good luck!
Old May 7, 2014 | 04:19 PM
laobo979's Avatar
laobo979
Go with gas lite on with less fuel and empty trunk...
Old May 7, 2014 | 05:29 PM
Gville350's Avatar
Gville350
Bypass the water box and NO burnout! In between the water box and line, romp on the gas once or twice to help remove any loose debris off the tires. If you stage shallow at the line, leave on the last yellow. If you stage deep (bulbs will probably go from two to one lit), then you'll want to leave closer the actual green. Also, if you can, arrive early and let the car sit with the hood open to help cool it all down.
Most of all, have fun!
Here's a couple of my passes : https://www.clublexus.com/forums/is-...-8th-mile.html
Old May 7, 2014 | 06:26 PM
specie's Avatar
specie
14.0@99mph with a 2.2 60'
Old May 7, 2014 | 08:17 PM
idoke1's Avatar
idoke1
^^not bad for your first time. Where did you do your 1/4 mile time at?
Old May 7, 2014 | 10:29 PM
specie's Avatar
specie
And a 14.2@98 with a 2.4 60'.
It was at gainesville raceway (FL)
Old May 8, 2014 | 10:58 AM
is350x909's Avatar
is350x909
Not bad. Definitely can get in the 13's with more practice.
Old May 8, 2014 | 12:50 PM
Gville350's Avatar
Gville350
Put it this way...much room for improvement. But I bet you still has fun huh!
andy350
Sep 1, 2021 03:08 PM
naldo92
Aug 22, 2015 03:03 AM
whooper20
Jul 15, 2011 12:42 AM
schan1w
GX - 1st Gen (2003-2009)
Jul 9, 2008 02:40 PM
