Air | fuel ratio question
Old Apr 29, 2014 | 03:50 PM
djsn1's Avatar
djsn1
Default Air | fuel ratio question
I installed my fsport intake over the weekend and my brother brought this to my attention.. With putting on a performance intake on the car does the air fuel ratio need to change or does it do fine with factory setting from the stock intake?
Old Apr 29, 2014 | 06:01 PM
mikellucci's Avatar
mikellucci
It will be fine with the slight WHP you just gained.
Old Apr 29, 2014 | 06:16 PM
Gville350's Avatar
Gville350
The ecu can adjust over time. I and many others though recommend doing a hard reset of the car's systems by disconnecting the battery for at least 20 minutes to force the ecu to re-learn everything right then and there. Let idle for 5-10 minutes, and then go drive it like you normally would.
Old Apr 29, 2014 | 08:34 PM
idoke1's Avatar
idoke1
^^Like the first two postings. You will be fine. The ecu will automatically adjust to it.
818GS
Performance
Apr 9, 2012 12:05 PM
Irishvol
Apr 23, 2009 07:11 AM
MCL1
Performance
16
Apr 17, 2009 09:40 PM
healerhand
Dec 22, 2001 12:48 AM
lexon20's
Oct 25, 2001 11:25 AM
