F-Sport Intake Installed, but....
ECU adjust the difference in air intake after the intake installation. From what I was recommended, after installation leave the vehicle on idle for 5-10mins so ECU could learn the difference and adjust. I think you could still do it. Just unplug the battery and leave it unplug for 20mins atleast.
Right, the MAF needs to learn that there is now more air coming in, Air - Intake - MAF - Intake Manifold... am i wrong?
Just talked to a buddy who works at Metro Lexus here in Cleveland, he confirmed that the battery does not need to be disconnected but is recommended. Even if you disconnect the battery without an intake, connect it, and go for a 'spirited' drive, your car will feel faster as a result.
Air box-> MAF-> F-sport tube-> Throttle body.
The MAF comes -before- the F-sport tube. The amount of air coming in is measured before it hits the F-sport tube. (or the Joe Z tube, or whatever you have there)
and even if it DID work the opposite way, it already would -know- how much "more" air was coming in, since that's sort of the point of the MAF.
They 'recommend' you disconnect it for 2 reasons:
1) To avoid you needing a new MAF if you do something really really goofy electrically.
2) Because, as noted, the car will immediately "feel" faster if you disconnect your battery for a bit, even if you change nothing else... so you'll feel more justified in having dropped the $ on your intake since this placebo makes you think the intake did that :P
