supercharging my is350
Old Apr 25, 2014 | 12:14 PM
  #91
Gville350's Avatar
Gville350
^Yeah, by then hopefully your car's systems will have calibrated it much better. Make sure you throw in some WOT pulls on the street too! Put in that bung, install the WB, install the meth setup, and return to dyno.
GL!
Old Apr 25, 2014 | 06:21 PM
  #92
mikellucci's Avatar
mikellucci
Stop buying new hardware for the car and put some miles on it! LOL Seriously, swapping parts and strapping it to the dyno will continue to yield unsatisfactory results. If anything positive came out of your dyno experience it was that you got to witness first hand just how good this ECM is at detecting knock and taking appropriate actions!
Def. drive it around and perform throttle blips to allow the ecu to learn the changes. Its not even so much miles related but varying driving conditions and open/closed loop changes.
Old Jun 6, 2014 | 09:13 PM
  #93
nikogio38's Avatar
nikogio38
Check out the new setup change location of filter plus new k/n filter. New Tial QRJ BOV recirculated!! Runs like champ now!!!
Attached Thumbnails supercharging my is350-1.jpg   supercharging my is350-02.jpg   supercharging my is350-03.jpg   supercharging my is350-04.jpg
Old Jun 7, 2014 | 06:28 PM
  #94
Gville350's Avatar
Gville350
Looking good! Just one question, shouldn't the BOV be after the MAF sensor? I've only boosted cars with a MAP sensor in the TB, so I cannot be certain; but one thing I noticed.
So exactly what issues did you encounter without recirculating the BOV?
Old Jun 7, 2014 | 06:52 PM
  #95
nikogio38's Avatar
nikogio38
Car would idle low when I came to a sudden stop or rpms would go low enough the engine just stopped. The car runs better with the new setup...I notice better throttle response.
Old Jun 8, 2014 | 10:40 PM
  #96
LexusGuyyy's Avatar
LexusGuyyy
amazing thread, what part of Washington are you at? Not many IS guys down here in Spokane
Old Jun 9, 2014 | 12:48 PM
  #97
Gville350's Avatar
Gville350
Nevermind about my comment about the BOV placement; I saw a turbo setup on a G37 that had the BOV before the MAF, which was before the TB.
Old Jul 6, 2014 | 07:36 PM
  #98
nikogio38's Avatar
nikogio38
Thanks...IM in the south/east part of Washington dry desert **** hole!!
Old Jul 6, 2014 | 07:48 PM
  #99
nikogio38's Avatar
nikogio38
Update got my PPE HEADERS installed 2 weeks ago waiting on ECU to relearn boost then it’s back to the dyno I’m hoping to be putting down 337hp to the wheels with the extra 2.3psi and PPE Headers. Also finally got my new pulley from the machine shop looks good already sent it off to get Surgrip coated here’s some pics 2.10". Need to weigh the stock headers I know I posted the weight of the PPE headers will try to get that posted later this week.
Attached Thumbnails supercharging my is350-abc.jpg   supercharging my is350-11111111111.jpg   supercharging my is350-222222222222.jpg
Old Jul 15, 2014 | 06:38 PM
  #100
nikogio38's Avatar
nikogio38
Weighed the STOCK OEM HEADERS W/CATS each side L/R each weighed 11.2 pounds. The PPE headers each weighed 9.6. So you save 3.2 pounds...
Old Jul 16, 2014 | 12:54 PM
  #101
mike33's Avatar
mike33
Looking forward to your dyno results... Keep up the good work
Old Jul 16, 2014 | 06:30 PM
  #102
nikogio38's Avatar
nikogio38
Dyno sheets coming soon as this heat wave passing 108 degrees today and in the 100s all next week
Old Jul 17, 2014 | 05:46 AM
  #103
heyarms's Avatar
heyarms
^ time for meth injection to help out with intake temps!!
Old Jul 17, 2014 | 07:25 AM
  #104
NYKnick101's Avatar
NYKnick101
looking fwd to the dyno numbers
Old Aug 8, 2014 | 04:16 PM
  #105
nikogio38's Avatar
nikogio38
Update: I’ve had a falling out with the shop that was helping me mod my car....My personal experience with them was not very pleasing sloppy work at least on my car, doesn’t complete what is originally agreed upon when car was dropped off. Left grease hand prints all over my head liner that I couldn’t get off. The list goes on.... Finally called it quits when my inner wheel wells were damaged because of them and lost a belt that was supposed to be installed on super charger that never was. 3 weeks later trying to get those issues fixed got the cold shoulder with that…Bummer I figured the shop matured after all these years of being in business…never again! If you live in Washington State in the 509 I WOULD RECOMMEND YOU STAY AWAY FROM KAIZEN SPEED located in Kennewick, WA!!!!!
