GS400 Stalled Today?!?!
Any ideas??
Here is my experience:
gas: no, no difference
SRT intake: did it before isntall
AC on: raises RPMs
TM plugs: did it before install
TPS: dealer told me it was fine, even when I was ready to pay for it
Throttle Body dirty / cleaned it: no, no difference
Old battery: OEM or Optima YellowTop: SAME
Recently, someone mentioned not letting the gas level get too low since at low levels, the pump is more apt to pick up debris from the bottom of the tank, thus clogging/choking the fuel line (but odd since its not an issue in D
)Others have reported the TPS change out working. Still others have been told by technicians it's not a fix. I dunno.
Force the issue with your dealer if you are still under warranty and TELL them to change out the TPS.
Keep us posted.
you guys should check your battery, that's might be the problem for "stalling" see if it needs to be replaced..
Stalling, while the engine is running, is as I understand it, typically a fuel, or air delivery issue at its roots, or combonation of the two.
While waiting for my car I hear another tech. report in to the service manager that the TPS was replaced & throttle body cleaned. I ask the tech. about the TPS & he's says Lexus has been changing them out. He says that they just go bad & they have been changing them out alot. He said this will fix the low idle issue. First they check the battery,connection,plugs,fuel filter,alternator,O2 sensor, TPS-Throttle position sensor. Hope this kinda helps. My old Y2KGS had idle problems but, after I changed my plugs to TM's. It completely stopped. I installed them, at 10K miles & put about 50K on them.
Paul
And start using that octane booster as we discussed.
