Boosting with the twins... is250 turbo build
Old Dec 25, 2013 | 06:00 PM
  #136
e46m3lol's Avatar
e46m3lol
Just got code p0300 which comes up as a misfire. The car doesn't seem to have one though. It's still idling perfectly
Old Dec 25, 2013 | 06:01 PM
  #137
e46m3lol's Avatar
e46m3lol
Originally Posted by smokyis350
I always miss the best thread on the forum in these sub-forums. Did you do a dyno before the twins?
Nope didn't get a chance to do a pre dyno. I pulled the trigger on this project too soon. lol
Old Dec 26, 2013 | 07:10 AM
  #138
SH4DY's Avatar
SH4DY
Have you gotten a wideband installed yet?
The P0300 is more indicative of multiple events not necessarily miss-firing constantly. You may want to pull a couple of spark plugs and see what they look like to make sure you're not detonating.
Most of the P0300 codes I've seen have been from spark plugs gaps being too wide on boosted cars that weren't from the factory.
Old Dec 26, 2013 | 07:27 AM
  #139
e46m3lol's Avatar
e46m3lol
Originally Posted by SH4DY
Have you gotten a wideband installed yet? The P0300 is more indicative of multiple events not necessarily miss-firing constantly. You may want to pull a couple of spark plugs and see what they look like to make sure you're not detonating. Most of the P0300 codes I've seen have been from spark plugs gaps being too wide on boosted cars that weren't from the factory.
Haven't gotten around to buying a wide band. I'll look at some online today. Noob question but do I have to buy a kit that comes with a bung and an o2 sensor or can I use one of my existing o2 sensors to read the A/F?
Old Dec 26, 2013 | 07:45 AM
  #140
SH4DY's Avatar
SH4DY
It's best to get a complete package. Even though the factory primary O2's may be widebands, I believe they are Denso units whereas most aftermarket WB's use Bosch sensors. The issue is that the outputs and offsets may be slightly different.
AEM and PLX widebands can be had for ~$150 on ebay. That's pretty cheap insurance...
In the mean time I'd still pull a couple of spark plugs to get an idea of how your engine responded to the highway pulls.
Old Dec 26, 2013 | 07:55 AM
  #141
e46m3lol's Avatar
e46m3lol
Thanks for the info. I'll be purchasing one of those AEM kits as soon as I can. I'll pull out some of the easy plugs this Saturday. Last time I did my plugs I had to remove the intake manifold first which took about 2 hrs (biggest pain in the ***!!).
Did you mention something about the plug gaps needed to be slightly less now that I'm boosted?
Old Dec 26, 2013 | 08:21 AM
  #142
SH4DY's Avatar
SH4DY
On my IS350 I didn't need to remove the manifold. Just one or two on the passenger side should be enough to give you an idea and those are easy to get to.
Honestly with our crazy 3 prong iridium plugs I'm not sure how effective closing up the gap will be. You'd want to try and adjust the primary (tallest) ground strap. IIRC on the Hemi's we went from .045" (stock) to around .032" on boosted stuff, .028" when running more than 7 psi. The necessity of this may be a better question for Mike and Gville as they've got some boosted mileage under their belts...
Old Dec 26, 2013 | 08:40 AM
  #143
e46m3lol's Avatar
e46m3lol
Yeah on the 350's it's much easier to access the plugs
From what I recall... my oem plugs were only a single prong and not a 3 prong. I'll wait for the guys to chime in on this before I start making adjustments to the plugs.
Old Dec 26, 2013 | 09:46 AM
  #144
heyarms's Avatar
heyarms
I've never messed with the gapping of my spark plugs. But I agree you should be a little proactive about getting a wideband and boost gauge up and running so you don't end up with a toasted engine if you're getting misfires and limp modes already. You can also buy a $25 OBDII dongle that can output tons of engine info as well as CEL codes onto your phone or tablet. Can be found on Amazon, any brand will work just do research on the app or whatever each use to output data. I use one in conjunction with dash command app on my iPad.
Old Dec 26, 2013 | 01:24 PM
  #145
Gville350's Avatar
Gville350
Don't do any HWY pulls until you figure out the misfire and oiling issues; that's when you put the most load on the motor and the turbo setup actually.
I've never boosted a motor with a factory-recommended iridium spark plug before; always been simple, cheap ($1.99) NGKs. But I'd recommend after putting some decent amount of miles on it and after letting the systems "re-learn" everything, I'd pull a plug from each bank and post up some macro shots of them.
You can learn ALOT about the health of a motor from just what the plugs are telling you :
Old Dec 26, 2013 | 09:56 PM
  #146
scott1256c's Avatar
scott1256c
I'm went to look back thru some of the pictures. Is that your MAF connected right close to your headlight assembly? If so, where is it now? From some reading today, aren't MAFs pretty sensitive to location and orientation? Wouldn't you ideally like to keep it about the same distance from the TB, in a straight piece of pipe, oriented like it was from the factory?
Old Dec 26, 2013 | 10:00 PM
  #147
e46m3lol's Avatar
e46m3lol
After messing around with the Position of the MAF... I ended up leaving it towards where the stock location used to be. It idles perfect and drives smoothly now.
Attached Thumbnails Boosting with the twins... is250 turbo build-image-2332672840.jpg
Old Dec 27, 2013 | 07:37 AM
  #148
ShawnD's Avatar
ShawnD
Look at Innovate Motorsports Wideband setups too.
Great progress and I'm interested in the boosted HP #'s!
Old Dec 27, 2013 | 07:45 AM
  #149
e46m3lol's Avatar
e46m3lol
Bad news... I was about to get in my car this morning to go to work and I saw this on the floor
Called in sick and I'll be pulling the turbos off today to see what the heck happened.
Attached Thumbnails Boosting with the twins... is250 turbo build-image-967671018.jpg   Boosting with the twins... is250 turbo build-image-2382979650.jpg
Old Dec 27, 2013 | 08:44 AM
  #150
e46m3lol's Avatar
e46m3lol
Pulled one turbo down...
Not sure what the problem is. Am I over oiling?
Attached Thumbnails Boosting with the twins... is250 turbo build-image-2743208162.jpg   Boosting with the twins... is250 turbo build-image-83498243.jpg   Boosting with the twins... is250 turbo build-image-1475607589.jpg   Boosting with the twins... is250 turbo build-image-3528274861.jpg
