How does the Fuel injection system work?
Old Nov 17, 2013 | 11:25 AM
SparksLex's Avatar
SparksLex
Default How does the Fuel injection system work?
According to Wikipedia, "The 2GR-FSE is a 3.5L engine used in the Lexus IS, and GS 350, incorporate Toyota's latest D4-S twin injection fuel system. This system combines direct injection with traditional port injection."
That sounds pretty interesting and I didn't know that some cars combine both. Can someone give me a good explanation as to how it works? The car has fuel injectors, I assume, but it also has fuel lines that go directly into the combustion chamber?
Old Nov 17, 2013 | 04:17 PM
Gville350's Avatar
Gville350
VVT-i D4 – “Direct Injection” engine technology
Toyota’s award-winning VVT-i (Variable Valve Timing with intelligence) engine has been improved by a small, but very effective new idea. Petrol is now injected directly into each cylinder through a new slit-like nozzle (see diagram and photograph below).
Perfect distribution of fuel around each cylinder
You will probably remember playing with the hosepipe in the garden: Squashing the pipe flat causes the water to fan out at high pressure. Toyota’s new VVT-i D motor uses the same idea to atomise and distribute fuel around each cylinder. Avantages: Increased fuel spray atomisation for more uniform combustion Compression ratio is increased to 11.0 (compared to 9.8 for the VVT-i engine) Petrol no longer sticks to the injection port during cold fuel injection, which results in less hydrocarbons, meaning a cleaner and more efficient engine. The VVT-i D4 engine is 8% more efficient than Toyota’s award-winning, and very economical VVT-i engine. ut most importantly, D4 makes a difference you can really see and feel!
Old Nov 17, 2013 | 07:28 PM
SparksLex's Avatar
SparksLex
So "combined" isnt exactly the correct term? It's more like just pure direct injection, and not a combination of the two?
Edit: I guess combined is correct
Apparently it uses the D4-S, and so does the FRS.
Old Nov 17, 2013 | 11:16 PM
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
The IS250 uses D4, the IS350 uses D4-S.
D-4 is direct injection only, with a single injector per cylinder.
D-4S is direct and port injection, with one of each type of injector per cylinder.
Jeff
Old Nov 18, 2013 | 10:00 AM
SparksLex's Avatar
SparksLex
Yep. Pretty wild stuff. I didn't realize how much of a focus there was on performance for these cars
Old Nov 18, 2013 | 07:24 PM
jdmSW20's Avatar
jdmSW20
yes the D4-S fuel system is pretty impressive. it also is the reason the the 350 doesnt get the carbon build up issue the the 4GR in the is250 get. the port injection somewhat washes it clean. thats not the point of the system but its a by product. i almost wonder why toyota didnt eventually give the 250 the same fuel system. it works in the 350 and the ISF
Old Nov 20, 2013 | 01:21 PM
redspencer's Avatar
redspencer
OG Member
Veteran: Marine Corps
Here's a link to a very detailed tech brief on the 2GR-FSE D4-S that I've kept over the years:
http://www.sae.org/automag/techbrief...1-114-1-17.pdf
This is one of the primary technologies introduced in the IS350 that made it a Ward's best engine for four years straight.
Old Nov 20, 2013 | 07:47 PM
Gville350's Avatar
Gville350
I still wonder if the port injectors could be upgraded on the IS350s to handle increased boost figures others have not seen AND still have the factory ecu control it all effectively.
Old Nov 22, 2013 | 01:13 PM
SparksLex's Avatar
SparksLex
Great article, red. Thanks for linking that.
Old Nov 24, 2013 | 06:44 PM
stewb10's Avatar
stewb10
That, my friend, is the million dollar question. Ill have to look into that.
Old Nov 25, 2013 | 05:48 AM
redspencer's Avatar
redspencer
OG Member
After looking at the original link that I posted earlier, I realized that it was not the full report on the development of the D4-S for the 2GR-FSE that I wanted to share. The PDF that I attached is what I originally meant to post and it should definitely answer your original question on how the fuel injection system works.
Old Nov 25, 2013 | 11:57 AM
WylieKylie's Avatar
WylieKylie
I think that question is basically answered in the first article posted by redspencer:
Originally Posted by SAE Article
Ultimately in high-rpm zone, 100- perecent direct-injection is used to obtain higher torque. “Simply stated, the ratio is dependant on rpm and load, but its control is extremely intricate and complex— for example, not impairing the system’s learning ability,”
So if the port injectors aren't being used at high RPM, then putting bigger port injectors isn't going to get you any more fuel at high RPM, which you are going to need to make more power at high RPM. That is especially going to be the case for forced induction, where (usually) you make the most boost at high RPM.
Old Nov 25, 2013 | 12:24 PM
Gville350's Avatar
Gville350
^Tried finding that quote in the PDF, but couldn't locate it. Trying to see what the context is off that statement.
Old Nov 25, 2013 | 01:12 PM
WylieKylie's Avatar
WylieKylie
It is in the link from the 1st article redspencer posted:
2nd page, last paragraph in the right column.
Old Nov 25, 2013 | 05:32 PM
Gville350's Avatar
Gville350
Hmmm, very interesting! Most just figured (myself included) that the port injection is scaled along with the rpms increasing; but according to the articles, it's far from that easy! In fact, they say is it constantly in flux.
I also read some interesting data in the second attached PDF from Red in sections 4.3 and 4.4. Something about they CANNOT do both types of injectors for extended periods of time due to the DI tips overheating and could possibly clog. So according to these articles the port injectors are really only used to maximize fuel efficiency, increase torque in certain areas within the powerband, AND during cold start-up to heat up the CATs as quickly as possible.
I enjoy reading such articles! You learn something new every day!
jbl-1985
Sep 18, 2014 05:28 AM
mtd2198
May 29, 2014 11:38 AM
bryanc182
Jun 30, 2010 05:06 AM
Cruizing
Dec 9, 2007 12:15 AM
zushwa
Maintenance
23
Jan 28, 2002 03:32 AM
