IS300 CD009 350z Transmission Swap
Old Feb 25, 2013 | 07:24 PM
  #46
Inspar8r's Avatar
Inspar8r
Originally Posted by airfed
Ar5 isnt a option just like the R154. Its 1000whp to get in the door. A 800whp IS300 is a big stepdown from my turbo 4 cylinder.
Well, the guy who did it in his solstice bis putting down over 800whp. Has survived no lift shifting, 6000rpm clutch dumps and a bunch of high speed 180mph runs. Not sure anyone has tested the limits on an ar5.
Old Feb 27, 2013 | 09:43 AM
  #47
exist3nce's Avatar
exist3nce
This is ****ty news indeed.... So are you saying you are dumping your IS300 altogether? Awesome that you went this far tho...
Old Feb 27, 2013 | 10:40 PM
  #48
white_is's Avatar
white_is
Considered a Z32/Z31 tranny? My buddy works for a Nissan dealership/has a vh45 swapped S14 and he is using the NA 5 speed out of a 300z. The NA is apparently the same internally as the Turbo tranny but has a smaller bell housing. He also has a CD009ish tranny out of a 370z and said the NA 5 speed is much smaller.
Collins and a couple others make adapter plates for it.
And I'm pretty sure it's the same/similar length to w55, and can be shortened. And I found a thread of a guy with an IS that did the swap. I couldn't tell for sure if he modded the transmission tunnel or not though.. I don't think he did.
I can possibly measure the width of it this weekend...
Old Feb 28, 2013 | 09:53 AM
  #49
airfed's Avatar
airfed
Yea its pretty much a dropped and moved project. I wanna drop a 2JZ hooked to a CD009 into something. The transmission in its stock form is what has me going. The GTE CD009 is a great combo...on paper. This chassis is my problem. Collins s13 has a CD009 in it right now. For the 6k on a v160 I can probably get a GTE AND a good rolling chassis haha. Once I find a chassis I will start a new thread in clublexus since the motor will definately be a 2JZ and link this thread as a pickup point.
Old Mar 1, 2013 | 09:46 PM
  #50
airfed's Avatar
airfed
Default Cd009 2jz e30
I found a chassis. My buddy has a 86' bimmer and he has a ton of more space than me. So he's gonna pick this project up at a little cheaper price than I did. Unsubscribe from this if you are here for the is300 tranny fail because it won't fit and im not cutting on my tunnel. Bimmer specs:
1986 325e
2JZGTE
T70 MasterpowerTurbo
ID1000 Injectors
A1000 Fuel Pump
Aeromotive A1000 FPR
TIAL BOV
90mm TB
Straight Piped
Custom Power steering
R154 (Blew up the 1st, installed this one recently)
HPF Feramic 700 Clutch
Newly installed Xcessive Solid trans mount with newly modified crossmember.
Custom Driveshaft with Chevy 1310 Ujoints
Welded 3.43 rear end
Newly installed BC Coilovers 10k 12k (wish I would have gone 6k8k)
E36 Rack
Cheap O' Buckets
No carpet mod
No interior mod
Newly Fabbed 6point Roll Cage
Custom Tilt
Borbet Type A 16x9
Rota something or others
Toyo 225/45/16 fronts
Whatever I can find rear
RCI 10gal fuel cell
Bash Bars front and rear
Haltech PS500
Airfed Tuned
Owner: Sleepydub
Original e30 thread in Bimmer forums. http://www.r3vlimited.com/board/showthread.php?t=278356 Lets be nice to the bimmer guys.
Drifting
vs 647whp Supercharged Z06
Drifting
Videos are on stock suspension, car has since had BC coilovers put on and is getting a re-wiring right now so its the perfect time to do the tranny swap. He has a ton of room and its sitting further forward.
Old Mar 3, 2013 | 06:52 PM
  #51
Inspar8r's Avatar
Inspar8r
I miss my e30.... Great car, great chassis.
Old Mar 3, 2013 | 10:08 PM
  #52
FIGS's Avatar
FIGS
The Maker
in for updates. Bummer on the SXE10 chassis but it will be good to see this happen for everyone in something.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old Mar 7, 2013 | 09:20 PM
  #53
airfed's Avatar
airfed
I snapped a few pics of the donor car when I at sleepydubs house. Car is still down but should be ready for a drift event on the 17th of this month. CD009 will go for a stab in this car after the drift event.
Couple pics:
The coil packs and map sensor will be moved to that square compartment behind the engine thats open. That should help with coil heat, apparently hes gonna have the wires come out of one spot of the cover that goes there and straight to the spark plug hole....should be pretty clean.
Tons of wires removed and carpet painted back jet black.
Throwback vids before the e85 tune.
Smashing a camaro on pump gas with no traction.
Drift practice.
Smashing another vette on pump gas.
Long live the 2JZ.
Old Jul 8, 2013 | 10:19 PM
  #54
webosc4's Avatar
webosc4
Hey have you look into a subaru STI gearbox???
found this http://members.iinet.net.au/~wearne/...ns%20Specs.pdf
Old Jul 22, 2013 | 04:07 PM
  #55
hatchguy's Avatar
hatchguy
Cool bimmer man I've always been a fan of that body style, that sucks about the tranny though that would have been a good option.
Old Aug 14, 2013 | 07:31 PM
  #56
vereak82's Avatar
vereak82
That bimmer is sick damn!!!
Old Mar 5, 2014 | 09:54 AM
  #57
HotcakesIS's Avatar
HotcakesIS
i think im going to try to hammer it in and see how that goes if not ill find someone to cut it. I have a 03 sport design manual with lsd
Old Mar 10, 2014 | 05:49 AM
  #58
airfed's Avatar
airfed
Your going to need to start at the firewall. The firewall opening will need 2-3" of banging at the radius as well as 2-3" the full length of the tunnel. In post 41 you will see the pic of the engine with bracket on it; this is with the engine hanging down as far as it will go and still barely any space. I do think the entire tunnel needs to be CUT out cause theres a huge size difference and the stock tranny barely fits itself. The shifter **** will sit in the cup holder but somehow i think that can be fixed. Would be nice if you make it work.
https://www.clublexus.com/forums/7784750-post41.html
Old Sep 9, 2015 | 09:14 AM
  #59
JasFarmer's Avatar
JasFarmer
Default Cbf performance internal forward mount shifter for the cd009.
I will just leave this here.
Old Sep 23, 2015 | 02:34 PM
  #60
freezingco's Avatar
freezingco
Awesome build!
