Resonator delete/Warranty
Old Sep 29, 2012 | 07:54 PM
jason3t3's Avatar
jason3t3
Default Resonator delete/Warranty
Noob question: Does void your warranty?
Old Sep 30, 2012 | 01:19 PM
My0gr81's Avatar
My0gr81
Would probably void emission component warranty, since it is part and parcel of the emission system.
Old Oct 3, 2012 | 04:14 PM
NorCalIS's Avatar
NorCalIS
No it doesn't, unless a problem is found to be derived from exactly that part they cannot void your warranty under I believe it's the Magnussen Aftermarket clause (someone correct me on the name haha). Since a resonator is a non moving part that literally only exists for sound purposes you'll be perfectly fine!
Old Oct 3, 2012 | 04:29 PM
projectdna's Avatar
projectdna
you're referring to the Magnuson-Moss Warranty Act.
and iirc, it applies to aftermarket parts, not modified OEM parts.
in the case of removing resonators, if there is an issue that is traced back to the removal of the resonators, the dealership can and should refuse to cover the work under the factory warranty, since the issue was a result of modifying an OEM part to circumvent its original function (i.e. noise reduction, emissions control).
so to answer the "will it void your warranty?" question...
if deleting the resonators cause an issue in the future, then yes, it will void your warranty.
Old Oct 4, 2012 | 07:07 AM
Kurtz's Avatar
Kurtz
nothing mod-wise will "void" a new car warranty.
But if the modding causes a problem they are not obligated to fix that problem
the rest of the car would remain under full warranty coverage.
swaangin
Mar 23, 2018 07:36 AM
melbitoast
IS F (2008-2014)
14
Oct 27, 2013 12:46 PM
RX300wannabeIS300
RX - 1st Gen (1999-2003)
Oct 25, 2002 10:38 AM
LKA18G
IS - 1st Gen (2001-2005)
Jul 5, 2002 03:18 PM
theDIESEL
Maintenance
Sep 25, 2001 11:23 AM
