aem intake yay or nay?
Old Jul 10, 2012 | 07:39 PM
aznoutkast's Avatar
aznoutkast
Default aem intake yay or nay?
wanting to get an intake soon...thinking about the aem intake, checked the site and says it has proven dyno numbers " +11 hp" . but it has to mess with the maf sensor. is there any other intake that will have proven hp performance . thinking about the Fsport intake or injen etc. thanks!!!!
oh and i dont want it to reduce my mpg either lol
Old Jul 10, 2012 | 08:24 PM
Hoovey689's Avatar
Hoovey689
2UR-GSE Owner
not all that glitter is golds and no you will not get 11hp with an Intake plain and simple. Doesn't matter what brand. At the most you gain is 3-4hp in the IS, that's it. Really your just buying into the sound. It might "sound" faster but that's just the "butt" dyno. sorry to disappoint..
Old Jul 11, 2012 | 05:28 AM
bob4256's Avatar
bob4256
The intake that will give you the most hp is the Joe Z or Fsport, which would be 5hp. All others will giver you ~5hp or may even make you lose a bit of power, none of which are noticable.
All short ram intakes are soley for sound
Old Jul 11, 2012 | 07:09 AM
stasis3131's Avatar
stasis3131
Just cut a hole in your air box and call it a day. Pretty much the same results and it's free99 . If you building a show car go ahead and get the Joe z setup
Old Jul 11, 2012 | 05:29 PM
A_Grasso's Avatar
A_Grasso
I had an aem intake for a little while and really liked it. Don't let others' opinions on an intake change your ultimate decision.
Old Jul 11, 2012 | 05:41 PM
anxiouz's Avatar
anxiouz
On nearly every car I've owned in the past several years I've always ended up with an AEM intake. It usually sounds great, is priced well, and is absolutely no worse than stock. So to me it was always a good purchase....although admittedly it sounds more awesome on a turbo'd car.
Old Jul 12, 2012 | 09:49 PM
aznoutkast's Avatar
aznoutkast
thanks ! hows your mpg?
Old Jul 13, 2012 | 04:23 AM
A_Grasso's Avatar
A_Grasso
Well, I had it with an exhaust and mid pipe so I didn't get any better mileage. However, when I had just an intake and no exhaust, my MPG actually went up a little
Old Jul 13, 2012 | 05:44 AM
Kurtz's Avatar
Kurtz
Your intake does not, and can not impact your gas mileage.
Anybody who thinks it does does not understand how a MAF/O2 feedback loop on a modern fuel injected car works.
(the above assumes the filter is clean and intake is correctly installed and isn't lying to your ECU about anything- the ones that lie CAN change mileage, but only for a short period of time before the MAF/O2 system tunes the lies back out)
If an OEM could improve gas mileage with a cheap intake change they'd have done that from the factory to improve fleet CAFE numbers.
akoster
Feb 26, 2021 12:34 PM
10lexISR6
RC - 1st Gen (2015-present)
34
Jun 26, 2019 07:16 PM
Whitelex09
Performance
12
Feb 22, 2015 01:59 PM
dotkong
Performance
Oct 16, 2008 09:51 PM
AKIS350
Performance
61
Oct 1, 2008 08:48 PM
