Help with intake choices
Old Nov 12, 2002 | 03:40 PM
dabiddle's Avatar
dabiddle
Default Help with intake choices
I am a new GS400 owner and feel the need to undo the stock restrictive air intake! Can you help me with these options?
1- use a K&N drop in filter
2- use a K&N drop in and modify the stock air box in some way to allow in more air
3-use a RMM, Injen, or WeaponR cone-type filter w/o an ECU upgrade
4-use a SRT cone-type w/ECU upgrade
While some intake noise is fine, I don't want too much! I just want more throttle response and acceleration. Any thoughts?
Is it true that a drop-in will gain 1-3 rwhp, a cone-type 7rwhp, and a cone-type w/ECU upgrade 10rwhp? Thank you!!
Old Nov 12, 2002 | 04:39 PM
UTGS400's Avatar
UTGS400
Default Re: Help with intake choices
If you want more throttle response and better acceleration, save up and get a torque converter. It seems to be a consensus on CL that a TC is by far the best bang for the buck when it comes to performance.
Second, if you are worried about noise, I would recommend meeting up with someone on CL that lives near you to hear how much noise their intakes make. You said a little noise is okay...what is a little noise?? Only you can judge if an intake is too loud.
IMO, you should either do the entire SRT w/ ECU or just stick with the drop in K&N drop in filter. If you are going to spend the money to get an entire intake put in, you might as well add the ECU. If I were worried about noise, I would probaby stick with the K&N drop in filter.
Hope this helps.
Old Nov 13, 2002 | 08:55 PM
dabiddle's Avatar
dabiddle
Default Reply re: intake
Thanks for the help. I think I will stay with a K&N air fiilter, but cutout part of the bottom of the stop air box and run a quasi-ram air intake through the grill near the fog light.
Old Nov 13, 2002 | 09:27 PM
1niceride's Avatar
1niceride
I agree with UT, save up for a TQ or get forced induction if you want performance. An intake won't make any noticable improvements IMHO.
Old Nov 13, 2002 | 11:56 PM
dabiddle's Avatar
dabiddle
Default Reply
What type of 'forced induction' systems have you seen for the GS400? I am only aware of home-grown systems?
Old Nov 14, 2002 | 12:50 AM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
Default Re: Reply
Dabiddle,
For one example click down one post (at least right now) and check on the Twin Turbo dyno post.
Here's a link in case it moved.
https://www.clublexus.com/forums/sho...threadid=63218
Old Nov 14, 2002 | 08:51 AM
///MDex's Avatar
///MDex
Default Re: Reply re: intake
Just be careful of putting the intake so low and open that it sucks up too much moisture.
00lexondub
Performance
Dec 26, 2003 02:35 PM
UTGS400
Performance
Nov 8, 2002 09:51 PM
kapdori
Performance
Jun 25, 2002 01:20 PM
RI-GS4
Performance
20
Jun 21, 2002 08:03 AM
Juan C. Cos
Performance
Dec 29, 2001 08:20 AM
