IS350 Revision S/C
Old Jun 13, 2012 | 10:13 AM
  #76
mikellucci's Avatar
mikellucci
Originally Posted by gompka
Are you tee'd inline with the evap clicky valve? They had the same setup in my scion tc with the trd supercharger and I changed it over to a much bigger and more isolated vacuum source also. I thought my bov became slightly more responsive after that change over, but might have just been in my head, i had an hks ssqv.
^Yes, and youre right that given the changes I've made with port config., etc. the bov seems lazy! The happy median is the way I have it now- blowing off fine at 3-6psi but anything under its a weak flutter. I'm def. going to tap a new port on the mani. this weekend....def. cant hurt. Thanks for the RE
Old Jun 13, 2012 | 10:28 AM
  #77
heyarms's Avatar
heyarms
Originally Posted by mikellucci
Hey bro, thats good news! I'd like to see you DIY as I can be of any help you might need and save you some $. I completely understand the convienance factor with the shop though. I would likely advise them or get their input around adding a better port on the intake manifold for pressure though. I think I'm going to tap one similar to Elias above!
Just tell em to look at my pics, I gave you the same spacers I had machined for the studs and the 2 tensioner pulleys. Its all together on the bracket but they'll have to undo it when installing of course. Take pics!
Man, I'd love to save the money and i know i could get it done, but i've just been lacking motivation these days to get in the garage... haha its too damn hot and humid in houston. I just would hate to have it half installed over the weekend and be stuck somewhere and have to burn days off from work. The piece of mind of everything being installed properly is worth it to me. If it wasnt my daily, I'd tackle it, but since its a daily, i cant risk my level of work failing me opposed to higher level work by my shop.
Either way, money is only money, people will hate that i'm doing this regardless, but i cant wait.
Old Jun 13, 2012 | 10:46 AM
  #78
projectdna's Avatar
projectdna
i hate you. only because you're doing this and everyone else... well, isn't.
Old Jun 13, 2012 | 11:17 AM
  #79
two2tone's Avatar
two2tone
I sooo wished I had $$ laying around for that LMS kit you sold :-( ... anyways this thread is sooo inspiring so much win!
Old Jun 13, 2012 | 05:49 PM
  #80
heyarms's Avatar
heyarms
Haha it will hopefully be quite the wild ride after this addition. FedEx failed to deliver today though so a Friday/Saturday install is in place. And yes, my shop thinks it'll take more than one business day, I think they can do it in a day tho!
save up and buy it off me when I part out one day in the distant future... Haha
Old Jun 15, 2012 | 05:58 AM
  #81
mikellucci's Avatar
mikellucci
New 1/4" npt barb tapped into intake manifold plenum for BOV. Should have much better response from the bov with its own line not sharing with the Evap. crap.
Old Jun 15, 2012 | 06:08 AM
  #82
gompka's Avatar
gompka
looks much better.
Old Jun 15, 2012 | 06:28 AM
  #83
HKS350's Avatar
HKS350
I have my BOV tee'd into the same line as my MAP sensor. I'm running 3/8 line to both. I then tee to 1/4 line at the BOV to ports A&B.
I'm using the 3/8 factory port on the manifold.
This type of BOV is piston driven and is ALOT more **** about input source.
Also, I have tried to vent the BOV and end up with the same issue's. I always repipe back into the intake.
I'm thinking the issue may be that your blowing off after metering the air. Where is your BOV placed, before or after your OEM MAF?
If after you must repipe or get the anti-stall kit.
The issue has to do more with fuel trim and cam timing causing flutter in the manifold.... this condition is caused by the lack of metered air in the intake manifold for the corrected cam timing.
With the HKS Fcon I have full control of cam timing and still couldn't stop the flutter.
If your blowing off before the OEM MAF then this ^^^^^ is null and void, proceed on sir!
Old Jun 15, 2012 | 07:14 AM
  #84
mikellucci's Avatar
mikellucci
Thanks. Yeah, thats why I was hesitant to repipe...my bov is Before the MAF - this is my common practice or petpeeve when it comes to Toyotas. Also, when I tried connecting ports a&b on the synapse the thing made my car sound like a Train chu chu chu puffing air out. Maybe I didnt give it a fair chance and should revisit?
Right now I'm in port A only on the Synapse.
Another thing I considered was just running 2 HKS bovs. I read a lot of the old issues with the HKS bov were related to it not being able to release enough air for the amount of CFMs a S/C pushed out. Two of them would seem to help with that issue..
Old Jul 17, 2012 | 12:55 PM
  #85
mikellucci's Avatar
mikellucci
Changes are on the way... Mocking up the new bracket now for a "real" supercharger-
Old Jul 17, 2012 | 12:56 PM
  #86
gompka's Avatar
gompka
Awesome, i always wondered what those were like and why they aren't used more often. Definitively watching the build!
Old Jul 17, 2012 | 06:24 PM
  #87
HKS350's Avatar
HKS350
OH' Snap!
HKS350 likey
Maybe this will help, HKS.jp bracket setup/belt routing
Old Jul 18, 2012 | 05:03 AM
  #88
mikellucci's Avatar
mikellucci
Originally Posted by HKS350
OH' Snap!
HKS350 likey
[/IMG]
I wish I would have bought the HKS setup from the beginning. I've wasted a lot of time and money!
Old Aug 14, 2012 | 06:24 AM
  #89
mikellucci's Avatar
mikellucci
Welllll
A lot of stuff will be posted for sale in the coming weeks.
Not sure whats next for me but in talks with the wifey around something "new!"
https://www.clublexus.com/forums/is2...harger-c2.html
Old Aug 14, 2012 | 02:04 PM
  #90
Gville350's Avatar
Gville350
Wish you luck with the sale and the what the future may hold! Perhaps an ISF?
