IS350 Revision S/C
Old Aug 16, 2012 | 06:58 AM
  #91
mikellucci's Avatar
mikellucci
Originally Posted by Gville350
Wish you luck with the sale and the what the future may hold! Perhaps an ISF?
Thanks. Plans keep changing but as of right now the wife wants to upgrade our third car....So I'll be keeping the IS350 in a lesser form and using the funds to contribute toward that.
After driving the car around for a number of consective days w/out the S/C I def. miss the power. It was VERY noticable throughout the power band and made the car much more fun to drive. Its funny how accustomed we become to something and then when its gone you appreciate it that much more. Def. not the same car now without the power and s/c screaming.
Old Mar 3, 2013 | 12:20 PM
  #92
mikellucci's Avatar
mikellucci
Default Back from the dead
Making so many changes to my car this winter I got motivated to start over! Excuse the mess!
Rotrex c38-71. Awesome blower!!!
If this looks familiar its because another Ohio guy whos making real HP enlisted Justin for the CNC milling! I went there a few weeks back
Out with old, in with the new....
and
8 ribs !
Dual sequential bovs
I luv plumbing!
R & D lol
I'll be buttoning this up in the next 3 weeks or so. Stay tuned!
Old Mar 3, 2013 | 01:22 PM
  #93
FordGT08's Avatar
FordGT08
Looks like a badazzz setup!
Old Mar 3, 2013 | 07:02 PM
  #94
heyarms's Avatar
heyarms
I'm confused with a few of your pics/what it all is.. Lol but I lack proper educating. Glad to see you back in the game.
Old Mar 3, 2013 | 07:08 PM
  #95
two2tone's Avatar
two2tone
oohh wowzer!
Old Mar 4, 2013 | 06:01 AM
  #96
AZ JB's Avatar
AZ JB
Subbed.. Can't wait for updates
Old Mar 5, 2013 | 07:42 PM
  #97
TrueStreet's Avatar
TrueStreet
Kick ***, can't wait to see how it turns out. I'm inexperienced with most turbo setups, so sorry for the noob questions, but what is the benefit of having sequential BOVs?
Old Mar 6, 2013 | 07:21 AM
  #98
mikellucci's Avatar
mikellucci
It's basically pointless at such low boost levels. However, I'm running 2 bovs to set release at different pressures. The biggest point of contention early on with my Procharger setup was dealing with compressor surge. I didn't like the compromise of eliminating compressor surge at low boost but having it at WOT runs. I think w/ 2 valves I can dial this in a bit better for my driving habits (boost levels).
Old Mar 6, 2013 | 07:31 AM
  #99
heyarms's Avatar
heyarms
I had to swap the spring in that HKS BOV i got from you in order for it to actually bleed off pressure. Went to the hardware strore and tried a bunch of springs, cut some, finally got one to fit and make the BOV work. It still sounds a little like compressor surge, but it blows off pressure from the BOV now at least. It doesnt whistle like i am told the HKS is supposed to sound though , oh well!
Old Mar 6, 2013 | 08:28 AM
  #100
Sffd103's Avatar
Sffd103
Fire Slayer
This looks like it's coming right along Mike.....i'm excited to see how it all turns out. Good luck!
Old Mar 6, 2013 | 09:02 AM
  #101
mikellucci's Avatar
mikellucci
Thanks! It'll be fun for sure! I'm getting anxious with Spring weather right around the corner.
LMS sold their "kits" with the HKS bov. I used a Synchronic bov on my setup with the spring completely removed. The results were still similar in that there was a fine line of compromise between compressor surge at 2-4 psi vs 5+.
Old Mar 6, 2013 | 07:53 PM
  #102
TrueStreet's Avatar
TrueStreet
ah ok interesting. Looking forward to your progress
Old Mar 29, 2013 | 05:01 PM
  #103
mikellucci's Avatar
mikellucci
Belts on belts on belts
It's almost buttoned up... Just waiting on my brembos and Advans to get back from powdercoating!
Got all the pulleys squared away with spacing and alignment.
Old Mar 29, 2013 | 10:34 PM
  #104
PAVGR's Avatar
PAVGR
Great job my friend.Icant wait for the results although i believe that this is a very big supercharger for that low boost.I really hope i m wrong
Old Mar 30, 2013 | 06:38 AM
  #105
mikellucci's Avatar
mikellucci
Hey man, I've been meaning to get back to your message! Have you started your build? You are friends with Elias, right? If you need fabrication parts, I'd be happy to help you.
This Rotrex is actually the blower the HKS setup utilizes....or one trim larger then the HKS blower. The plots are pretty spot on for our engine. Check out what Stew ended up with if you haven't already. We've been back and forth on our projects for a long time now!
https://www.clublexus.com/forums/is-...350-dynod.html
Curve:
