06 is250 AT Transmission Jolting
Old 02-04-12, 11:33 AM
nosleepis
nosleepis's Avatar
Default 06 is250 AT Transmission Jolting
Hello everyone, I have an 06 is250 with automatic transmission. The car feels and drives great, except for when Im coming to a stop and the spedometer hits about 5-10 mph the transmission jolts and I hear a cunk....
EVERY other gear, and at ANY other speed the car shifts smoothly/perfectly.
This just started happening.
Is my trans completely gone, how long do I have to replace?
Or could it be transmission mounts?
Thank you, in advanced.
Old 02-04-12, 12:56 PM
itruns
itruns's Avatar
Without driving/seeing/more information about the car it is hard to diagnose. It could be several things. Axle CV joints, mounts, universal joints ect... You need to get someone to look at it soon as continuing to drive it "might" cause more damage... The IS's seem to have a fairly robust trans, we do not hear of many problems....
Old 02-04-12, 02:09 PM
Onakz80
Onakz80's Avatar
How much mileage you have on the car? I have the same exact car and it kinda feels the same way when i come to a full stop, have about 60k on it....
Old 02-04-12, 04:55 PM
Gville350
Gville350's Avatar
Change your information display to the gear selection. At the time you hear that noise see if that's when it is shifting from second to first gear.
Old 02-04-12, 05:05 PM
Uda880
Uda880's Avatar
I had the same symptoms on the 350. Seems to be exactly what Gville350 just described, the jolt mainly comes from in traffic driving, during stopping and shifting from 2nd to 1st.
Is this normal?
Old 02-05-12, 12:56 PM
Gville350
Gville350's Avatar
Try switching the car into snow mode and see if that helps with the jolt of the gear selection.
Old 02-06-12, 08:00 AM
nosleepis
nosleepis's Avatar
I've put it in gear selection and it happens only when the car's shifting from 2nd to 1st gear. Sometimes it doesnt happen at all, however, I recon that's because the car is getting used to my style of driving....(maybe)
I've just bought the car, with possible transmission issues, however, I bought it for such a good price (several thousand below retail) I couldn't pass up the deal. I purchased a 100,000 mile warranty, but it doesnt kick in for another 60 days.
My IS250 has 114k miles. Motor is strong and smooth...but I think the person who had it before me might of killed the trans...possibly.
Gville, I did switch it to snow mode and it still jolted a bit.
Old 02-06-12, 12:12 PM
Gville350
Gville350's Avatar
Ah, a new purchase. Do a reset via disconnecting the battery. It'll force the car to re-learn your new driving habits. Afterward you will need to manually "program" the each window to go up...so don't be freaked out. Search for details.
Old 02-08-12, 10:25 AM
nosleepis
nosleepis's Avatar
Actually, I put it in power ect mode and it doesnt jolt anymore from 2nd to 1st....but I think it's my transmission because many times in 5th the accelerate and RPM's go up, but no car movement....its like the gear slips or something.
And one time it didnt want to go into 4th from 3rd gear through paddle shifting.....
I'm going to get it inspected soon, I just haven't had any time at all.
Old 02-08-12, 01:25 PM
Gville350
Gville350's Avatar
5th gear slipping is not good at all. Do you at any time get a transmission buring smell? Inside or outside the cabin?
Old 02-08-12, 07:18 PM
ms2619
ms2619's Avatar
I tried in snow mode and no jolting, but it just sucks because my IS350 feels like a 4 cylinder then lol
Old 02-09-12, 02:24 PM
White350
White350's Avatar
get the transmission fluid changed
i find when customers come into the shop complaining of similar symptoms i change the fluid and that solves it most of the time
Old 02-09-12, 02:26 PM
White350
White350's Avatar
the car won't downshift if your rpm's are too high and it'll beep are you
the car shouldn't really go from 2nd to 1st unless you are stopped at a light even with paddle shifting it wont go in unless you are doing like 10-15 mph
Old 05-01-24, 09:02 AM
matthewwxd
1st Gear
matthewwxd's Avatar
Default Jolting
Hi. I’m having this jolting issue. May I ask what fixed the problem????
jehmin
11-10-22 09:12 AM
Cp116
05-17-21 06:35 AM
Dx3
08-18-18 04:37 PM
97lexuses3
03-20-14 06:36 PM
Quick Reply: 06 is250 AT Transmission Jolting
