What sould be a quater mile time
Old Sep 22, 2002 | 12:14 PM
jcramair1's Avatar
jcramair1
Default What sould be a quater mile time
What should be a quarter mile time with the following mods:
RMM limited slip differential
Swift Intake
Dragon Tourque converter
Old Sep 22, 2002 | 12:39 PM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
jcramair1
There are a lot of other variables other than the three mods you listed (tires, type and weight of wheels, driver and car weight (from stereo mods, etc) altitude/temp/humidity, etc.), not to mention the largest variable - the driver.
IMO best case (assuming excellent traction, good launch and a light car) you're looking at anywhere from 13.8 - 14.2.
Old Sep 23, 2002 | 11:14 AM
Mean Gene's Avatar
Mean Gene
Smile My Best
J - I have all of those mods plus several years of running at my local track & the best I've laid down was a 13.79 @ 102.86 mph. This was with the 200# of trunk stereo equipment but before the Torquemaster plugs ( which my previous dyno tests on a friend's GS4 show a significant improvement ). Maybe when things cool off down here I'll run things again to see what an additional 40k miles have done to things.
Old Sep 23, 2002 | 11:37 AM
Shinchan's Avatar
Shinchan
Hmm.. don't know.. but I have most of the stuff listed.. beside the RMM LSD.. I have the TRD LSD... but the car sure feels quick...
Old Sep 23, 2002 | 05:31 PM
MikeGS4PE's Avatar
MikeGS4PE
14.1~14.4 @ 98~100 mph stock...gets faster and faster each time I go to the track
usually like a 2.1 0-60 ft
Old Sep 26, 2002 | 03:37 PM
RocketSlug's Avatar
RocketSlug
1998 GS400, K&N Filter in stock air box and synthetic oil
Run#(degrees F)
One (66) Two (66) Three (66) Four (66) Five (63) Six (59)
R/T 0.752 0.449 0.427 0.93 0.737 0.724
Sixty 2.207 2.254 2.246 2.275 2.28 2.281
Three Thirty 6.351 6.443 6.422 6.464 6.502 6.493
Eighth 9.679 9.802 9.786 9.829 9.885 9.874
Thousand 12.536 12.681 12.676 12.726 12.796 12.781
Quarter 14.924 15.086 15.091 15.15 15.231 15.214
1/8 MPH 74.63 73.77 73.53 73.65 73.29 73.29
1/4 MPH 95.54 94.94 94.34 94.14 93.75 93.75
Old Sep 26, 2002 | 03:47 PM
RocketSlug's Avatar
RocketSlug
Scratch that. The above if from my current car 2001 GS 430 Injen Intake, 255/40/17 rear tires. My 98 was faster, so far.
I just added the TM spark plugs a month ago. Temp yesterday was 73 with 60% humidity. I did 15.1xx. This is the first run with the Torque Masters, but since this is a much warmer temperature, it make me think it will be quicker the next time I go out to the track.
Summary: TM plugs, Injen intake, and 1% smaller tires resulted in 15.1xx at 73F 60% humidity. I am guessing at 59F this should plunge below the 15 mark.
Old Sep 28, 2002 | 03:13 AM
LexusL's Avatar
LexusL
Sounds like GS400s times boy I don't one to put my gs300 time up there hehhehe......me and my 15. something seconds.... or maybe 16 i dont how fast a gs300 is exactly.
Old Sep 30, 2002 | 04:43 PM
JBrady's Avatar
JBrady
Rocketslug, hmmm... I can tell from your R/T and 60 foots that you know how to drive. I am surprised by your ETs in the 15.1xx range. Your car should be quicker. You mentioned air temps and humidity and those were almost the exact same as my last runs. What is the altitude at your track?
Here is my slip for comparison. My first run of the night was a 14.78, next was a 14.73, then this 14.69 (on a 14.68 dial in ). I am in the right lane. All runs in the 95+mph range with a best of 95.82mph. This is in my 99 LS400 with air box mod, removed final mufflers and removed full size spare. Torque braked to apx 2300rpm and left in "D".
Old Oct 1, 2002 | 05:56 PM
tmasta's Avatar
tmasta
how does everyone launch? power breaking? using the e shift for shifting??? thanks!.. and is anyone running these times with 19's or 20's???
T
Bakewalk
IS F (2008-2014)
Mar 29, 2015 05:12 PM
mdgrwl
Drag Strip
Feb 21, 2013 01:35 PM
Hameed
Performance
Mar 31, 2003 07:08 PM
