Aristo JOBD Code/Live Data scanning. Greddy/Blitz Displays??
Old May 13, 2013 | 01:56 PM
  #61
Meyagi's Avatar
Meyagi
the app torque pro also can read the jobd ecu with a $13 bluetooth dongle. reads codes, realtime data etc
Old May 14, 2013 | 09:26 AM
  #62
1aristo's Avatar
1aristo
You got this working with the Jdm vvti ecu?
Could you list the parameters that can be seen, and is the data reliable?
Old Jun 5, 2014 | 06:24 AM
  #63
1aristo's Avatar
1aristo
Update....The greddy informeter touch only gives a count of how many engine codes are present but does not give the actual code number
Old Dec 22, 2014 | 10:16 AM
  #64
TheDuecer's Avatar
TheDuecer
any real updates on this?
Old Dec 23, 2014 | 08:21 PM
  #65
Beserker99's Avatar
Beserker99
Smile
I recently just got my Torque app working on my car the other day with a generic bluetooth OBD2 device. I'm in Australia, and our cars don't seem to be OBD2 compliant like that in the USA, so I assumed that we're still using the original Japanese diagnostic protocol.
Anyway, someone had managed to find a way for the app to communicate with their Japanese JZA80 TT ECU, so I thought I'd give it a try on my car.
To my surprise it actually worked, and I can get live data from the ECU now. I've only tested basic gauges, but all seems to be fine.
Info can be found here:
http://www.2jzgarage.com/2013/01/2jz...d-information/
Buy a ELM327 scanner tool – ELM327 Interface Bluetooth OBD2 Auto Scanner V1.4 OBDII
Purchase and install Torque Pro Android software – Torque Pro Google Play
In the vehicle profile of the Torque Pro application add the following line in the VERY ADVANCED ELM327 section
ATIB 96 \n ATIIA 13 \n ATSH8213F0 \n ATSP4 \n 0100
Old Nov 26, 2017 | 10:47 AM
  #66
komar's Avatar
komar
I bought the app $5.00
2001 GS works normally.
2002 GS swap.
- The app is not working on this car so far.
- I did the Very Advanced section addition.
- Any tips?
thanks,
Old Feb 4, 2019 | 06:17 PM
  #67
Arussto's Avatar
Arussto
Default Tachyon works
Tachyon toyota obd2 dingle opting for kwp toyota in the settings gives fuel trim air flow etc etc. Map pressure air intake temp etc. Those that I remember in addition to basics like ignition advice throttle post etc Also does proper DTC sentences. Android software and windows also which I never got to work. Android works fine except sometimes it unexplainable disconnects and you have to click connect.
Talapo
May 15, 2017 11:58 AM
sj408
Feb 22, 2013 03:06 PM
2jzgttegs
Aug 22, 2011 06:27 AM
slappy96
Oct 2, 2009 11:31 AM
slappy96
Aug 3, 2009 09:05 PM
