Used Transmission Questions
Old Jun 25, 2011 | 01:46 PM
CPALex's Avatar
CPALex
Default Used Transmission Questions
I have to replace the transmission in my 98 GS400. its slipping badly between 2-3 and 3 - 4. I've found a used 98 GS transmission with 10K miles which I have verified through autocheck.com. The transmission was pulled out of a GS that had been totaled from front end damage in mid 1999. The transmission has been sitting since that time. Might there be a problem using a transmission that has been sitting for so long? Thanks!
Old Jun 27, 2011 | 04:14 PM
vwynn's Avatar
vwynn
This i would like to know too.
Old Jun 28, 2011 | 10:56 AM
CPALex's Avatar
CPALex
Since posting I've talked to my mechanic and he said that as long as the transmission initially had oil in it that there wouldn't be a problem. He pointed out that rebuilt transmissions often sit for a long time before they installation. That's good enough for me.
Old Jul 5, 2011 | 03:25 PM
TheMadGS3's Avatar
TheMadGS3
I would think that it would take some HEAVY HEAVY damage to ruin a transmission in an accident, but I suppose anything is possible.
Old Jul 5, 2011 | 03:53 PM
DeanGS's Avatar
DeanGS
I would agree that most of the time a transmission can sit inside or covered off the ground with no issues. If it sat outside then contamination (rust, dirt, etc) can be a problem. Having fluid in the trans will def help. If you can inspect before picking it up put some fluid in it and sping the torque converter. Fluid should come out of the cooling lines (the torque converter drives the main fluid pump). Check the fluid to see it's condition.
Old Jul 8, 2011 | 09:44 PM
bigwasum's Avatar
bigwasum
buy it and flush it
leg3ndary
Oct 18, 2017 12:41 PM
MikeysSC
Dec 10, 2005 02:13 PM
