Hyper Grounding Kit???
Old Jun 9, 2011 | 10:39 PM
is250noob's Avatar
is250noob
Default Hyper Grounding Kit???
What's the deal with the Sun Auto Type S Hyper Grounding Kit for the IS crowd? What is it supposed to do? Does it even help with anything important? I saw it's supposed to "reduce emissions, improve MPG, and increase power." It is only like $100, but is it even worth it?
Old Jun 9, 2011 | 10:55 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
It looks pretty. That's about it.
Old Jun 9, 2011 | 10:57 PM
is250noob's Avatar
is250noob
Even if I were to install it with a Hyper Voltage system? It just seems like an easy mod that "claims" to have positive things for it, but would it literally be a waste?
Old Jun 9, 2011 | 11:38 PM
projectdna's Avatar
projectdna
this man speaks the truth.
Old Jun 10, 2011 | 12:06 AM
JoshIS408's Avatar
JoshIS408
- - G T V I P - -
it will let you rev over 9000
Old Jun 10, 2011 | 12:11 AM
509IS350's Avatar
509IS350
Lol. 10 char
Old Jun 10, 2011 | 07:35 AM
is250noob's Avatar
is250noob
Haha ok I get it. Total waste unless I want something that "looks pretty" under the hood.
Old Jun 19, 2011 | 02:05 PM
FutureITR's Avatar
FutureITR
I believe the Lexus is pretty well grounded...
It really only works (not even noticeable) on my RSX.
Old Jun 19, 2011 | 02:27 PM
Sffd103's Avatar
Sffd103
Fire Slayer
Looks REAL puurrrdy!!
Attached Thumbnails Hyper Grounding Kit???-motor-shot-at-blox.jpg   Hyper Grounding Kit???-stereo-rush-350-3.jpg
Old Jun 19, 2011 | 09:12 PM
kannon's Avatar
kannon
Lol it actually does look pretty cool.
Old Jun 20, 2011 | 08:44 AM
kuuqi's Avatar
kuuqi
It's all relative.
For our cars, it looks pretty. For older cars, it may help. Since older vehicles tend to have grounds corroding, it will affect the vehicle's performance marginally. You're realistically "restoring" what was lost by getting a grounding kit. Granted with out vehicles, they're not old enough to have such problems.
If you do plan to install one, your best bet is to go to home depot and pick up proper wiring and make a homemade grounding kit to have the same effect. The only benefit of purchasing a "kit" is it looks prettier and it's premade. Granted if that's what you're going for then by all means go for it
Hope that helps!
Old Jun 20, 2011 | 10:33 AM
lobuxracer's Avatar
lobuxracer
Tech Resource
Or put anti-seize on the bolts in your existing ground system to provide unquestioned low resistance at the points most likely to be problematic.
Also - Hondas use a horrible daisy-chained system for grounding with more ground loops than a geothermal HVAC system. I can see a grounding kit adding value in a Honda. Toyota's engineers are really good at getting their electrical systems right. If you ever want a first class education on automotive wiring, subscribe to TIS and look at just about any of the EWD repair manuals. They're phenomenally detailed and prescriptive for how to do wiring right. Toyota's relative freedom from electrical problems compared to all other manufacturers speaks volumes about how well they get this done.
Old Jun 22, 2011 | 05:40 PM
montgb's Avatar
montgb
I got mine for looks.
evopanop
Feb 28, 2011 10:14 AM
Pnuge88
Feb 29, 2008 10:36 AM
biglexass
17
Sep 5, 2006 06:47 AM
jstyles129
Aug 31, 2006 12:12 PM
LexAnt
Jul 26, 2005 04:52 PM
