for the na-t guys
Old May 5, 2011 | 08:45 AM
ZippyGuy's Avatar
ZippyGuy
Originally Posted by supratp23
When you guys are using the FIC are you all using a plug and play harness? or just wiring it in?
Plug and play. If you ever need to return your car back to original and/or if you upgrade F/I management to a stand alone your OEM wiring will be in tact.
Old May 6, 2011 | 10:06 PM
supratp23's Avatar
supratp23
what plug and play are u using?
Old May 7, 2011 | 01:15 AM
mex lex's Avatar
mex lex
Boomslang Fabrication
Token Solutions
Old May 7, 2011 | 06:27 AM
ZippyGuy's Avatar
ZippyGuy
AEM plug and play
http://www.aemelectronics.com/engine...oller-f-ic-13/
Old May 7, 2011 | 07:41 AM
3UZFTE's Avatar
3UZFTE
I had to go standalone. MS3 w/MS3x card is my setup, I'm still in the process of install. But I'll be running sequential fuel and spark on E85. I could've gone piggy back, but for the price, I couldn't beat it for the tune ability.
Old May 8, 2011 | 11:59 PM
supratp23's Avatar
supratp23
Originally Posted by mex lex
Are you guys using the one made for a IS300? Which year?
Will these work with a 2000 sc300? I know the motors are the same but is all the wiring the same between the cars.
Old May 9, 2011 | 05:50 AM
ZippyGuy's Avatar
ZippyGuy
If you go to the manufacturers website for the product they will guide you to select your engine and/or vehicle. At least they do with the AEM site.
Old May 9, 2011 | 12:56 PM
99SC42's Avatar
99SC42
Yes it should work, they have the same connectors AS far as i know.
Old May 11, 2011 | 07:04 AM
kenc15's Avatar
kenc15
Thanks for input guys and i've started my collection of parts and I'm ready to boost this bad boy
Old May 13, 2011 | 07:41 AM
kenc15's Avatar
kenc15
Originally Posted by Alexus_300
For the power range you're looking to make, I really don't see the point of upgrading your rod/piston. I'd say just get a GTE gasket and some ARP head bolt and use something like a SAFC-II to tune things. Also, add in a NGK wideband with the NTK sensor for tuning and keeping an eye on things.
have you or anyone used a gte headgasket for their na-t set-up. i was thinking about that cost of things and if its cheaper and can hold up why not. like i said just looking for 325-350, if they hold up on gte pushing 500whp i guess it should hold on 325.
Old May 13, 2011 | 09:07 AM
99SC42's Avatar
99SC42
The gte gasket will hold 1000hp on the right setup fuel, tune and right combo.
Gte gaskets works great i used that on my setup, don't use the BL 2.5mm crap the gte will be more than enough for you.
Hell you can make 300-325 on stock compression w/o the hg.
Old May 14, 2011 | 10:05 PM
SZA's Avatar
SZA
So the general consesus is that the AEM FIC is preferred over any other piggy back system for the na-t guys? I was hoping for a little more information among all products mentioned in this thread and what is/are pros, cons for each counterpart. Thanks.
Old May 14, 2011 | 10:34 PM
tjmhillz's Avatar
tjmhillz
I would def talk to shaun at token solutions. He knows the ins and out of the Aem Fic and would help you without a doubt.
Old May 16, 2011 | 01:23 AM
SZA's Avatar
SZA
Will do, thanks. Surprising how much you can learn just by lurking. I cant wait to finally start modding my 99 cinnabar. I havnt done a darn thing to it except change the oil/regular maintenence in the last 5 years iv owned the car. Time for some boost!
Old May 17, 2011 | 04:46 PM
Alexus_300's Avatar
Alexus_300
this is exactly what I had set out in terms of power goals so I only changed out to the GTE head gasket which helped lower compression and all else is the same in terms of engine work.
pd-cuevas
Aug 20, 2013 05:33 PM
2j300
Apr 20, 2012 12:52 PM
GoCarSc300
Dec 29, 2007 10:14 PM
jxd
Performance
Apr 20, 2007 10:56 PM
