Ok.. 2JZGTE motor is ordered.. Time to start getting everything lined up
Old Apr 19, 2011 | 08:34 PM
Htowncory's Avatar
Htowncory
Default Ok.. 2JZGTE motor is ordered.. Time to start getting everything lined up
Ok guys..
Did research, found 98-01 GS300's are perfect for 2JZGTE swaps.
So, I found a one owner, 2000 GS300 low mileage great condition silver exterior, black leather interior GS300 with no spoiler.
Im loving it!
Now, Ive ordered the complete 2JZGTE engine, transmission, wiring harness, ecu. Should be arriving in a week or two.
Next I need to make sure I have everything else figured out.
Im wanting to keep the stock twin turbos for now. Im reading that theres interference between the heater core coolant line and the stock twins. I can get around that, no problem.
Im reading that theres a longer coolant line needed, no problem.
Supra turbo throttle cable needed, no problem.
Now, will I need to run a return line, regulator? Im wanting to keep everything as stock as possible for now (except for front mount intercooler and charge piping of course). I see several people have run return lines but it seems like its always guys who've converted over to single turbos.
Any other pointers on what else Ill need to get this running parts wise?
Thanks guys!
Cory
Old Apr 20, 2011 | 05:24 AM
99 GS3's Avatar
99 GS3
Thanks guys!
Cory
You should run a return, the gte has a fuel pressure regulator on the fuel rail so you need to run a return line to the gas tank and eliminate the regulator in the tank. Most here have used a jet pump killer to accomplish this and keep the siphon system working.. There's a few diy photo threads around on adding a return line.
You also need the driveshaft, and a remote mounted power steering reservoir.
KyleH
Build Threads
165
Nov 19, 2024 05:14 AM
702aristo
Performance
Jun 15, 2010 08:31 PM
papodotcom
Oct 15, 2007 12:37 PM
Tommyd1919
Dec 10, 2002 03:18 PM
