How to Install Fujita Intake?
Old Mar 16, 2011 | 05:26 PM
LEXAUDI's Avatar
LEXAUDI
Default How to Install Fujita Intake?
Ive been searching and cant find a write up on installing a Fujita short ram intake, I just purchased one used, and it seems self explanatory but can someone post a DIY write up on installing it?
Old Mar 16, 2011 | 05:55 PM
CarbonDtls's Avatar
CarbonDtls
K&N has a similar design and they have instructions. Fujita's website is horrible and provide no online instructions.
http://www.knfilters.com/instructions/69-8701_inst.pdf
Old Mar 18, 2011 | 01:53 PM
LEXAUDI's Avatar
LEXAUDI
Any other detailed write ups for an intake? I'm handy but still are sketchy about doing the install with no instructions
Old Mar 18, 2011 | 07:49 PM
LEXAUDI's Avatar
LEXAUDI
Question: why does the k&n intake come with a heat shield but the fujita does not? Also would it be a bad idea to not disconnect the negative terminal before install? I don't want a check engine light
Old Mar 20, 2011 | 06:46 AM
LEXAUDI's Avatar
LEXAUDI
BumppppppPpp
Old Mar 20, 2011 | 08:07 AM
quick123's Avatar
quick123
The heat shield is just a feature of the K&N intake...by reducing hot air going into the engine = more power, so that is why most people going after HP will op out of a short ram and go with the Joe-Z (utilizes the factory "ram" air for colder air)...short rams give awesome sound, but will take in hot air from the engine compartment, so the F-sport is a great combo of both...I went with the Joe-Z for the lower price
Here is a great step-by-step on how to install the F-sport intake from the Sewell website, this should give you all you need:
http://is.sewellparts.com/pdf/PTR0353100.pdf
Hope that helps
Old Mar 20, 2011 | 12:12 PM
LEXAUDI's Avatar
LEXAUDI
Thanks a lot!!!!
airjordan1
Performance
16
May 4, 2021 06:05 AM
Dante486
Performance
Nov 28, 2018 05:05 PM
jennypenny
Feb 13, 2014 10:07 AM
Matt_RN
CT 200h Model (2011-2017)
61
Feb 8, 2013 01:33 AM
Z1K
May 4, 2012 06:31 AM
