CL Please Help gs400 wont start until i gas it!
Old Feb 10, 2011 | 09:16 PM
dtan1691's Avatar
dtan1691
Default CL Please Help gs400 wont start until i gas it!
Almost every morning when i come out to the car i start it and it would crank up and then die on me like the rpm is too low.. Then i would gas it as soon as it cranks for a second and the car is fine... i have never seen the car above 700 rpm.. even when it is a cold morning... i am in ga and the weather is about 30 degrees in the morning.. any help would be greatly appreciated!!
Old Feb 14, 2011 | 07:40 PM
dtan1691's Avatar
dtan1691
ttt can anyone help me out??
Old Feb 14, 2011 | 07:49 PM
Lexus827's Avatar
Lexus827
is the check engine light on ?
Old Feb 14, 2011 | 08:26 PM
aprince1's Avatar
aprince1
Does your gas pedal stick?
Old Feb 14, 2011 | 08:37 PM
dtan1691's Avatar
dtan1691
thanks for the response guys but my check engine light comes on every few hundred miles and off throwing a catylic converter code then goes away after about 30 miles of being driven and will come on again within the next few hundred miles... and my gas pedal does not get stuck! Anymore help would be greatly appreciated
Old Feb 14, 2011 | 08:52 PM
aprince1's Avatar
aprince1
Check your pvc. Take it out and shake it. If it does not rattle that is your culprit.
Old Feb 14, 2011 | 09:09 PM
neojungle1's Avatar
neojungle1
im not to sure if the v8 IAC sensor may have to be replace or clean out just a idea out there
Old Feb 15, 2011 | 10:33 AM
Ceezo's Avatar
Ceezo
catalytic converter most likely is out...jack it up and bang on it, if one rattles thats the one
Old Feb 15, 2011 | 06:46 PM
dtan1691's Avatar
dtan1691
thanks guys for all the help! i cleaned the throttle body and maf sensor today and the car runs like a champ now!! idle is back to normal thanks again!
rtriplett3
Jun 26, 2013 11:46 AM
calikid747
Mar 4, 2013 09:28 AM
samoanboy
Maintenance
Sep 15, 2009 07:19 PM
98SC
May 27, 2008 10:27 AM
