How does your GS430 feel with a 3.76 LSD compared to stock?
Old Jul 6, 2011 | 01:58 PM
IAGS400's Avatar
IAGS400
Originally Posted by CT430GS1
Do they make less gear for the GS 430. lets say a 273:1. how did the 376 gear change inpact the speed0??? did it read a high reading on the dash than the car was travleing?
Someone please correct me if I am wrong.
The speedometer uses a sensor after the differential so the only thing that can mess up your speedometer is tire diameter.
Old Jul 6, 2011 | 02:05 PM
DeanGS's Avatar
DeanGS
Nope, speed sensor (for the speedometer) is on the tailshaft of the transmission.
Old Jul 7, 2011 | 07:17 PM
IAGS400's Avatar
IAGS400
I did a search and found a few posts stating the GS uses the ABS sensor which is located at the wheel. When you look at the "I just installed my 3.76 differential" threads I didn't find anyone making changes for their speedometer.
Old Jul 7, 2011 | 07:54 PM
DeanGS's Avatar
DeanGS
On my car, 2005 GS3, if I disconnect the speed sensor on the trans the speedo stops working. When going to a 3.73for a 3.26 rear end gear the speedo will read ~15% higher than actual (assuming stock wheel diameter is retained).
Old Jul 11, 2011 | 09:03 AM
sam430's Avatar
sam430
I think the cable comes along the drivershaft towards the right rear wheel spindle. It's reading the rotation of the rear wheel.
Old Jul 11, 2011 | 10:56 AM
DeanGS's Avatar
DeanGS
That's interesting. I'll have to disconnect the rear wheel sensors and see what happens. Maybe the trans sensor is just some type of backup sensor.
SorrGwa
Nov 28, 2011 08:15 PM
TTurboPimp
16
May 21, 2010 01:38 PM
swegs430
Performance
May 17, 2010 03:36 PM
