GS430 into GS400
Old Dec 20, 2010 | 01:58 AM
Team Rukus's Avatar
Team Rukus
Default GS430 into GS400
hey guys i am wondering if anyone can tell me if its possible to throw in a gs430 motor into a 98 gs400?
i would be using the stock harness and tranny on the my 98 same with the ecu until i get it chipped later. but wondering if all the plugs etc..would plug up to all the sensors and work with no issues?
Old Dec 20, 2010 | 02:00 AM
swegs430's Avatar
swegs430
Hi just a question! when u say chipped! what exactly do u mean by that?
The standard ecu or are u replacing it?
Old Dec 20, 2010 | 08:39 AM
3UZFTE's Avatar
3UZFTE
Anything is possible. However if I remember correctly, the 3UZ ecu uses a pass-lock system and you'd likely have to transfer over the ECU, ignition switch, key, extra. With that being said, I'm not sure if a 1UZ harness and ECU will work on a 3UZ. You can always run a standalone ECU and bypass all the junk. Motor to motor, they are the same block, with slightly varying internals.
Old Dec 20, 2010 | 09:28 AM
ThomasGS4's Avatar
ThomasGS4
Uhh.....why?
Old Dec 20, 2010 | 09:37 AM
fordsvtmfl's Avatar
fordsvtmfl
Originally Posted by 1UZ-GS
Uhh.....why?
+1...
Old Dec 20, 2010 | 09:44 AM
sakataj's Avatar
sakataj
theres a guy who did it with his SC400...IM assuming its essentially the same swap
contact him if u got any ?'s
https://www.clublexus.com/forums/mem...spdrcr771.html
Uhh.....why?
Originally Posted by fordsvtmfl
+1...
maybe he blew up his gs400 and he can get the gs430 block for cheap guys,maybe he likes the drive by wire,who knows
Old Dec 20, 2010 | 09:52 AM
EN_VY's Avatar
EN_VY
I don't see a point You get almost identical HP
Old Dec 20, 2010 | 10:10 AM
werewolf's Avatar
werewolf
.3 liters more...that's why..j/k
Old Dec 20, 2010 | 11:03 AM
excluesive's Avatar
excluesive
displacement FTW
Old Dec 20, 2010 | 01:01 PM
goldgs400.'s Avatar
goldgs400.
I say try for a 4.7L block...... maybe?
Old Dec 20, 2010 | 02:10 PM
sakataj's Avatar
sakataj
this is a good thought to go with
Old Dec 20, 2010 | 02:18 PM
DarKnight's Avatar
DarKnight
You're getting about the same power levels and probably less support from aftermarket.
Old Dec 20, 2010 | 04:53 PM
1QWKGS4's Avatar
1QWKGS4
Yeah, like 3UZFTE said, "anything is possible" but the 430 was design to be a different car than the 400. The 430 tranny was redesigned to be smoother and less mod friendly - not sure if the 430 motor can sync with the 400 tranny. There are other similar issues like electronics and drive by wire issues..
IMO - Since i do own both cars - though they look Identical - they drive and perform different than one another.. Save yourself a hassle an just replace the car with its original motor...
Old Dec 20, 2010 | 06:47 PM
ThomasGS4's Avatar
ThomasGS4
Scooter's is a lil' different. He has a 430 block with a 400 head.
Old Dec 21, 2010 | 07:36 AM
sakataj's Avatar
sakataj
oops, thanks parker...i thought he did the whole swap, thanks for the correct info
