What is this dash light?
Old Jan 26, 2010 | 07:55 AM
c4lvin's Avatar
c4lvin
Default What is this dash light?
I don't have the owners manual with me (I'm at work) and I have no idea what to search for.
At first, I thought it was informing me my bulb(s) were out on the rear tails, but that's not it (I think, since I have never had a car that can do that lol). The light has come and gone the past couple of days and it usually stays on until I shut the car off for a few minutes or longer then turn it back on.
Forgive the bad cell phone picture.
Old Jan 26, 2010 | 08:31 AM
young's 96's Avatar
young's 96
one of your back lights are out thats what it means trying checking that light in back window also.
Old Jan 26, 2010 | 08:38 AM
shvc1991's Avatar
shvc1991
It might be a pain in the ***, but try checking all the rear lights for loose connections. I had a buddy with a similar problem and it was because his inner tail light bulb was moving around and getting a bad connection from being a little loose.
Old Jan 26, 2010 | 04:32 PM
a#'z's Avatar
a#'z
Well if you just installed some LED tail lights, and it came on then yeah you have to bypass it. but other then that, yeah i agree burnt out or something...
Old Jan 27, 2010 | 04:09 AM
Emil's Avatar
Emil
as above rear light gone somewhere,you need to take the 10mm nuts off from in the boot,and then the two from the outside,you'll see two black cover's which need to be pryed up with a small screwdriver,and then your nuts (lol) will be there
loose plug also causes this as i found out,boot full of luggage caused the light to come on,empty boot i had no light...
Old Jan 27, 2010 | 08:08 AM
c4lvin's Avatar
c4lvin
Thanks for the responses, guys.
I had my girl look for burnt out bulbs, but she said everything came on fine (reverse, brake, parking, blinker, etc), so I'm sure it's just a wonky connection somewhere. I need to check it out this weekend.
Old Jan 27, 2010 | 08:10 AM
lowNslow's Avatar
lowNslow
i have the same light i gotta check this out too
Old Jan 27, 2010 | 01:00 PM
sakataj's Avatar
sakataj
mine did this also and it took me a minute to find them.....sometimes my bulb would light up, sometimes it wouldnt.
check the third brake light in rear window if your wingless, the SIDE brake lights on the tails and the inners....trust me one is out all mine looked like they were on but finally i found one that sometimes lit up and sometimes didnt.
why dont u try her sitting in the car and turning the lights on and pushing the pedal so YOU can look
Old Jan 27, 2010 | 09:55 PM
GCOP's Avatar
GCOP
CL Folding 100,000
mine seems to come on at ramdom, obviously I have a loose connection somehwere. Everytime I look back there, all the bulbs are good.
Old Jan 28, 2010 | 09:02 AM
JeffTsai's Avatar
JeffTsai
The light indicator is usually pretty accurate. I'm sure you have a light out and your gf couldn't tell. The outer taillights are hard to tell with an unexperienced eye. There are like 3 sets of bulbs in there per taillight I think, and a total of 5-6 filaments. If one is out, then it will make that light come on. It's hard to see if you don't look carefully. Either way it doesn't matter because you shouldn't get pulled over for it, but having the light on the dash can get annoying. Legally you're only required to have 2 tail light bulbs operational. The GS has a total of 8 lol!
I think you should switch spots and have her hold the brake while you take a look.
Old Jan 28, 2010 | 11:39 AM
c4lvin's Avatar
c4lvin
Thanks Jeff.
The light is off now randomly.
Old Jan 28, 2010 | 12:18 PM
JeffTsai's Avatar
JeffTsai
One of your bulbs probably just has intermittent contact. It was happening in my other GS. I just pulled the bulb out and reseated it and my problem went away.
klvaleri
GS - 1st Gen (1993-1997)
Oct 21, 2009 07:08 PM
EvilAristo
Oct 12, 2009 10:57 AM
yoda86ed
Oct 15, 2007 08:01 AM
Sweetser
Mar 22, 2007 07:55 PM
