Supercharged GS430
Old Oct 21, 2009 | 09:23 AM
erikbang's Avatar
erikbang
Default Supercharged GS430
Hey guys...I wanted to post up my recent supercharger build/experience. The install is complete and here is the quick and dirty, if anyone has questions please respond.
So here is the jist of the install:
3" polished aluminum pipe
12x24x3 intercooler
ATI P1SC With Lextreme Bracket
autowerks bypass valve
walbro 255 hp in tank
3.9" pulley
ngk v power bkr 7e plugs
stock everything else
custom made front hood support bracket because I had to remove the original for the front mount, as seen in pictures.
had to do a bit of grinding on the front, near the head lights where the intercooler pipe comes up and down near the end tanks where the pipes come in to meet the intercooler.
The biggest issues I found was trying to figure out the idle issue like we spoke about and the intake pipe to the procharger. I had to do A LOT of fine trimming and grinding to make something work. You don't see it in the picture yet because I haven't got the filter. Also the horns need to be relocated, as seen in picture. I will update you with the pic. I only want to run somewhere around 4-6psi that way not having to worry about detonation. I'm not planning on driving it until i have a wideband and boost gauge. You say that with the 3.9" I should be somewhere around 6psi?
Here is a link to lexteme forums, I'm sure you all know his retail sight where I purchased the bracket? It is the fish 2. He was really great to deal with, if there is any problem don't hesitate to ask.
http://www.lextreme.com/forums/showt...9564#post99564
Old Oct 23, 2009 | 09:50 AM
DumpedGS's Avatar
DumpedGS
can you post the pictures here? i dont have a login at lextreme to view the pics...what are you into this $$$ wise?
Old Oct 23, 2009 | 09:51 AM
DumpedGS's Avatar
DumpedGS
oops never mind...i didnt see the other thread...i will post my ?'s there..
badblackgs
Performance
233
Jun 7, 2019 07:02 PM
t2d2
Dec 9, 2015 05:32 PM
erikbang
Performance
47
Aug 30, 2015 08:47 PM
Rock-a-Lex
Performance
24
Dec 17, 2010 05:36 AM
GSV8
Performance
12
May 30, 2007 09:51 PM
