How easy is easy (installations)?
Old Apr 17, 2002 | 03:23 PM
twenty1's Avatar
twenty1
Default How easy is easy (installations)?
I've had my 98 GS4 for almost a year now, and the last few months have been a complete eye opener for me, as far as mods that you can do to your GS. I've never changed an air filter, spark plugs, or oil, and these are things that it seems like CL members deem simple. So, my question is, should I attempt to try changing
air filter?
spark plugs?
oil?
ECU?
on my 4, or should I just pay the price, and have it done professionally. And if so, is Lexus the only way to go as far as service goes, or are there other options for service that would work just as well? I had a mechanic before that I was happy with, but I trusted in him being knowledgable about my Accord, since those are a dime a dozen (plus, he allowed me to pay him in installments if I wanted). Now, with a much rarer car, I don't know how confident I could/should be in his ability to change oil, change brake pads/calipers, or any other routine service, without possibly creating problems for me/my car.
Old Apr 17, 2002 | 03:55 PM
RacingAristo
Guest
Posts: n/a
a good mechanic should have the fundamental knowledge of "cars" and be able to apply it on various vehicles. I trust my mechanic from changing oils to implement a turbo.
Changing ECU is really easy and you can find a lot of installation guides in CL using "search feature".
Old Apr 17, 2002 | 05:32 PM
Default Re: How easy is easy (installations)?
Originally posted by twenty1
...should I attempt to try changing
air filter?
spark plugs?
oil?
ECU?
YOU can change the air filter. It's a drop in piece. There's a giant plastic box in the front left of your engine compartment. The top of the box is held on by clips. Undo the clips, remove the top of the box, remove the filter, drop in a new one, replace the box, and you're done.
Unless you're really strapped for cash or **** retentive, I personally don't think changing your own oil is a good idea. It's messy, you have to dispose of the oil, and I've known people who even very experienced have made mistakes like putting brake fluid in the engine (eek!) or forgetting to put any oil in the car after draining, or stripping the bolt on the oil pan, etc. Your Honda mechanic though could definitely change your oil for you. I get mine done at the dealer because I like the fact they wash and vacuum my car after. It's $36 at the dealer, vs. about $29 at JiffyLube.
Changing spark plugs is pretty straightforward I think, although I've never done it. I don't know if you still have to check spark plug gaps like you had to years ago. If so, forget it.
If by ECU you mean the steering ECU, I did it, and I'm NOT very mechanically inclined. Just take your time, and it still shouldn't take more than an hour at the very most.
Old Apr 18, 2002 | 07:45 AM
BananaGS's Avatar
BananaGS
Tech Guru
I won't let any unknown person especially any car shop touching my car, even Lexus unless if absolutely needed. I do everything myself.
No one care about your car like yourself. you never know what damage do to your car if you let someone else touch it. if it's gonna damage, I want to be the person that did it, then I can't blame anyone.
With a body kit, my car can bearly make it on the lift at most shop, if the machanics is not careful, he WILL mess something up.
If you need pratice, find another car in the family and do your oil change, change filter, spark plug....once you know how to do it for one car, you know the rest.
(BTW, you don't need to change ur sparkplug til 100k, if I remember correctly, change air filter is like walk in a park hee hee)
anyway, but if you are not comfortable with doing it, Don't do it. You need to enjoy what you do.
just my .02 cent
Anh
Old Apr 18, 2002 | 11:57 AM
LexusRules's Avatar
LexusRules
for GS300 changine the spark plugs is a pain the ***.. you have to take of the throttle body because its in the way of the spark plugs. the easiest is air filter, followed by oil and oil filter (should be done together) and finally spark plug. on GS4 it shouldn't be too hard, its all about hte location of hte plug.
Heres a tip:
if you are just want to learn mechanics make a list of the things you have to do so you dont miss a step, and think about each thing before you do it. this way you can avoid ir-reversable problesm (running a car with no oil) if you PM me i woudl be glad to share some more info with you
Old Apr 20, 2002 | 05:46 AM
whitels's Avatar
whitels
just my .02 cent
Anh
Same philosophy here. Only to a Lexus mechanic unless absolutely necessary (especially after warranty expired). The only time I can be stopped is if I don't have the tools and usually they are the expensive but rarely used factory SSTs.
I spend $32 changing the oil and filter on my own but I use Mobil1 and OEM filter. Drain it starting Friday night and cap the drain Saturday or even Sunday depending on my weekend schedule. I get 1/2 quart more of dirty oil.
Why do I do it? I just love tinkering with cars...period. But to answer your question....yes you can do the air filter, spark plugs, oil, ECU.
To erase your fear, tackle them one at a time. Think of solving a puzzle before you attack. Imagine your game plan. Start with the simplest task like the air filter. Know its location, figure out how it can be accessed, separate the other components next to it to even make it look simpler and easier to get to, make mental or physical notes of how it stays in place, which side faces up or down, back or front, etc. When you feel like it's doable, and you can put it all back to the same configuration, then attack it. If you doubt something, bounce it off here at CL or get yourself a service repair manual. It can be both fun and challenging.
Old Apr 20, 2002 | 08:05 AM
Did you just read "Zen and the art of motorcycle maintenance"? (That's a real book by the way.)
Old Apr 21, 2002 | 09:47 AM
whitels's Avatar
whitels
bit-
No. Just talking from experience. You're also into motorcycles?
Old Apr 22, 2002 | 05:33 PM
No. Tried them but decided that while they might be fun once in a while I wouldn't get enough use out of one. Too hot, too cold, too windy, rainy, etc. No thanks.
Old Apr 28, 2002 | 06:08 PM
LS4fun's Avatar
LS4fun
I recently changed my air filter...
I did take me 2 hours however...
The SRT intake piggyback ECU takes a little bit of careful work...
stlgrym3
Jul 7, 2016 08:30 PM
NobleSpine
Jan 9, 2013 08:22 AM
Mesca
Oct 14, 2012 06:55 AM
stech
Aug 20, 2011 01:47 PM
Thinktwice
Apr 11, 2011 09:42 AM
