800hp is350!!!
Old Jul 14, 2009 | 02:35 PM
haulinick's Avatar
haulinick
Default 800hp is350!!!
OK, not really, but its basically the same motor minus the direct injection(pistons, slightly different heads, and of course the fuel system). its the 2GR-FE found in the new camrys and avalons.
http://www.supraforums.com/forum/sho...d.php?t=467852
check it out. maybe theres some sort of hope after all for boost on our cars.
btw, dont flame this thread with the usual "it will never work" BS. Lets try to be optimistic!
Old Jul 14, 2009 | 02:53 PM
JDKane527's Avatar
JDKane527
CL Folding 25,000
Niice!
This might be a cheaper engine to drop into a 250 or 350 instead of a 2JZ. Will probably still have little electronics remaining functional though, but is a good find and brings hope.
Old Jul 14, 2009 | 03:12 PM
Kurtz's Avatar
Kurtz
This isn't a flame- it's just pointing out that different pistons, different heads, different rods, different valves and springs, different cams, and a different fuel system- all custom, is really NOT "basically the same motor"
Old Jul 14, 2009 | 03:13 PM
badx33's Avatar
badx33
omg thats sooo koool, this really does give everybody hope..
Old Jul 14, 2009 | 03:54 PM
kickin8's Avatar
kickin8
2IS/2RX/4RX
800hp is over-rated?
Old Jul 14, 2009 | 04:05 PM
Sytfu_IS's Avatar
Sytfu_IS
very, cause your only going to be able to put about half of it on the ground unless you a freeway king LOL
Old Jul 14, 2009 | 04:36 PM
HKS350's Avatar
HKS350
Re-post, LOL...... Their is another motor that is in the 2GR family also. It is already supercharged, DI and displacement is 3.5L. But only found in Australia. It is the Toyota Aurion. 3.5L 2GR-FE factory supercharged (provided by TRD) Eaton style supercharger. HP - 323 - TQ - 300
The bore is the same and the piston will work in our motors. This ^^ motor is DI also, so they have the piston design down for boost. This would be easy work if someone wanted to buy some factory pistons and swap them out. It would hold @ 12-15lbs of boost from what I've read. Tuning is another issue.
andper10
Performance
Jun 2, 2016 04:51 PM
92 SC400
Oct 15, 2014 11:05 AM
Enginerd
Jul 29, 2008 11:30 PM
Koz
Dec 6, 2006 12:01 PM
05RollaXRS
Jun 24, 2006 03:19 PM
