Trans oil cooler pip leak! Help!
Old May 26, 2009 | 01:54 AM
117's Avatar
117
Default Trans oil cooler pip leak! Help!
Hi guys,
Got a bit of a problem with an oil leak on my 1998 GS300, basically when the car is running, I am getting a constant drip from the pictured pipe (just in front of oil sump) on my car, however it stops when the car is switched off... on further investigation this pipe appears to go to the transmission oil cooler. Has anyone seen this type of leak before? Do you think it is caused by the worn out rubber hose? Would it be safe to replace myself and would I lose a lot of trans fluid when it is removed?
Thanks for your help guys.
Old May 26, 2009 | 07:21 AM
Infamous 1's Avatar
Infamous 1
Change it yourself and get new clamps. When you take off the only hose make sure to get something to block the fluid from leaking. Should be pretty easy to do.
Old May 26, 2009 | 07:26 AM
GS300ToM's Avatar
GS300ToM
DIY... easy as job!!!! like what infamous said block off that hoes with like a screw or somthing that would fit in there.. thats what i normally do, works perfecty.. GL with it
Old May 26, 2009 | 08:17 AM
117's Avatar
117
Hi Guys,
Thanks for a quick response!
Any ideas of the Part No, Ive tried ******* but seems a little vague, guess ill need a new rubber pipe and the 2x metal clip things for each end?
Old May 26, 2009 | 08:36 AM
GS300ToM's Avatar
GS300ToM
look it up on sewell site
Old May 26, 2009 | 11:22 AM
JeffTsai's Avatar
JeffTsai
You don't need any fancy part number for that. Just bring both the old hoses to your local auto parts store and tell them you want one with the same diameter. Have both hoses there so they know how long to cut it. Make sure to tell them that you're need the hose that is rated for automatic transmission fluid. Regular rubber hoses will dissolve when in contact with ATF for prolonged periods. Then pick up four hose clamps that are approx the same size as the spring clamps and then you're good to go as far as parts. Everything together should cost about $10. If you were to buy all of those things from the dealer, you would be looking at around $30-40!
I'd suggest you do a trans flush while you're down there anyway. It's very quick and easy to do.
Old May 26, 2009 | 11:26 AM
vwynn's Avatar
vwynn
agree with Jeff.. just go to Kragen or pepboys... also might as well drain n fill your AT since your already down there.
byefi
Nov 11, 2018 12:23 PM
85Krtagena
17
Oct 12, 2012 08:57 AM
Aries
Sep 5, 2006 01:33 PM
ddana88
RX - 1st Gen (1999-2003)
20
Jul 27, 2006 10:15 PM
kschwenk
Jan 6, 2005 08:51 AM
