Evolved GS300 turbo install
Old May 2, 2009 | 04:50 PM
EvolvedGS3's Avatar
EvolvedGS3
Default Evolved GS300 turbo install
I had a pretty bad month in April, so I decided to spend some time in the garage to find my chi again.
Here is pretty much what happened
It started off with a timing belt install and ended up with a turbo kit install.
Stock is so gay
new timing belt installed
intake removed
stock header with 2 cats
stock midpipe with 1 more damn cat
exhaust manifold test fit
turbo test fit
The turbo didnt fit due to placement issues with the strut tower. The choice was simple, find another manifold, go with a smaller turbo, or get creative. So a little fabrication was in order
Once that was taken care of I needed to get the FMIC mounted. It didnt require a whole lot of work to get the 4" core to fit.
had to get it to stay in place, so a new brace was made
Old May 2, 2009 | 04:51 PM
EvolvedGS3's Avatar
EvolvedGS3
finally the crash support was trimmed and fitted over the intercooler. I would have cut out the center portion to allow the intercooler to get more air, but I am going for a slightly modified sleeper look with the GS.
The oil return mount was drilled (oil pan had the outline cast into it so it was damn easy) and tapped
The oil sending line was mocked up with a stainless steel / teflon unit that sucked *****. It was later replaced with a custom made hydraulic line by my local car parts shop. The battery was relocated to the trunk for room, and the fuse box was placed farther back away from the turbo to keep her from getting too hot.
A very good buddy of mine Aaron came by to help out with the install. Poor bastard is getting ready to be famous in a minute. It looks like Modified Magazine decided to use him in an article coming up on Evo X's.
Downpipe modified with the 4 bolt flange, and dump tube.
Thermal wrapped for her pleasure
final install with the turbo. Time to mock up the intercooler piping.
Due to the unique way toyota likes to place the intake manifold, we needed to fabricate the cold side piping by segmenting it JDM style. I am starting to get better at this welding thing.
Old May 2, 2009 | 04:52 PM
EvolvedGS3's Avatar
EvolvedGS3
Intercooler piping done, painted and starting to look decent
Pressure checking the system to verify my welds are good and we have no leaks.
Wiring up the fuel controller. It started with just an SAFC, but due to a bad unit and a good friend, I ended up with a NEO.
Bumper on and everything finished up (or so I thought)
I had to go back later and change the Maf over to blow through
You have to be low to see the intercooler
Why yes I am stock, why do you ask?
To celebrate the new power, I decided to step up the size of the tires on the back
This sadly, was a tad bit bigger than the factory had considered reasonable, so a little trimming was in order.
Old May 2, 2009 | 04:53 PM
EvolvedGS3's Avatar
EvolvedGS3
due to my new metal shears not working on folded and massively rubberized I had to resort to old trusty.
Thanks to this great product I wont be seeing any rust on my little girl
Sitting pretty
So I found my Chi again, now comes the next project for me.
I plan on building a new block to handle the power I really want to see out of this car, plus swapping over to a 5 spd tranny.
But all of that will come in time.
handoverfi's Avatar
handoverfi
how much power you looking to throw down and how much?
Old May 2, 2009 | 05:20 PM
EvolvedGS3's Avatar
EvolvedGS3
with this motor and tranny looking to sit at 300.
With the new motor and tranny, maybe 5. Haven't driven a gs300 with 500 before. Might be nice.
Old May 2, 2009 | 05:34 PM
Mr.NA_T's Avatar
Mr.NA_T
Nice build, keep us updated with the build with the new motor..
Old May 3, 2009 | 06:44 AM
schase's Avatar
schase
good work homie
bone stock turbo is the way 2 go
how much psi u runnin how is the neo workin for u
i recently also install my neo and it gave me a great uptairs
great sleeper
Old May 3, 2009 | 07:51 AM
ElitistK's Avatar
ElitistK
you might want to relocate all the electronics wiring and connectors on the exhaust side towards the coilpack area.
Old May 3, 2009 | 08:00 AM
EyeKutr's Avatar
EyeKutr
Looks like a fun DIY afternoon project, I am sure I can knock this one out in a couple of hours....WOW man, you are the man
Old May 3, 2009 | 08:27 AM
gs4play's Avatar
gs4play
Just wondering what you started off with, how many miles on motor and tranny and do you plan to upgrade the tranny sometime in the future. If so what mods are you planning?
Old May 3, 2009 | 08:57 AM
EvolvedGS3's Avatar
EvolvedGS3
started with a 163K engine bone stock.
tranny will remain stock until the new engine is built. Then I am swapping over to a 5 speed.
only running 7psi. Plan to stay right there until the new engine is ready to roll. Then we get to see how much power these engines can really handle stock bottom, stock head, stock tranny.
Old May 3, 2009 | 10:01 AM
mex lex's Avatar
mex lex
Very nice start! I can't wait to see what this will progress into. I'm curious to how far you'll push the stock drivetrain!
Old May 3, 2009 | 11:20 AM
olmytsi's Avatar
olmytsi
What turbo is that?
Old May 3, 2009 | 11:35 AM
ExileLakai's Avatar
ExileLakai
very nice work. How much time did it take you tart to finishs? a few weekends?
