jammed perch...need help
Old Mar 24, 2009 | 07:42 PM
ChrISF's Avatar
ChrISF
Default jammed perch...need help
i don't know how this happened...but my bottom perch is stuck/jammed/too tight.
Note* these are not my pictures, just using them as reference...but i do have JIC coilovers.
this is where it's jammed
and when i try to loosen it, this is where it unscrews...
that can't be good. need opinions on what you guys would do? taking it to a shop and having someone else check it out is out of the question.
Old Mar 24, 2009 | 07:56 PM
iSuxeL's Avatar
iSuxeL
Take a flat head and hit it with a hammer a few times, most likely it's stuck with road debris.
Old Mar 24, 2009 | 08:01 PM
ChrISF's Avatar
ChrISF
i tried that...but i stopped before further damage...it chipped the edge of one of the opening on the perch...i don't want to keep doing that. i also sprayed some PB Blaster (stronger than WD40) in the groves and that didn't help. but you are right, i'm sure its from the stupid salt debris...f my life.
Old Mar 25, 2009 | 11:44 AM
iSuxeL's Avatar
iSuxeL
Try something bigger like a piece of wood, anything that doesn't damage the perch.
Old Mar 25, 2009 | 12:02 PM
Sgt_K's Avatar
Sgt_K
Try using a strap wrench to hold the strut assembly between the two nuts and try and loosen the upper nut. Or have someone else hold a wrench on the lower nut and you try and loosen the upper nut.
jlault2953
Build Threads
Jan 4, 2015 01:53 PM
buckwhite
Suspension and Brakes
26
Sep 14, 2011 11:55 PM
llllllllll
NELOC
23
Apr 30, 2010 10:45 AM
donktan
Apr 21, 2006 09:33 PM
cutecboy
Mar 19, 2002 07:23 AM
