Apexi NEO wiring diagram help please
Old Dec 15, 2008 | 06:51 AM
Bliggity's Avatar
Bliggity
Default Apexi NEO wiring diagram help please
I will be removing my srt ecu and replacing it with an Apexi neo, unfortunately I will be getting the neo w/out the manual so I need some help. I searched for the diagram on here and noticed there were some discrepancies on which diagram to use for the neo, will someone that has done the neo or knows exactly which diagram is correct please inform me. Thanks, Blake
Old Dec 15, 2008 | 08:23 AM
Rock-a-Lex's Avatar
Rock-a-Lex
Well, I bought a plug 'n' play harness for my "Neo-to-GS400" connectivity so I didn't have to solder into my ECU harness; so I can't help you with your install. I am positive I can find the paperwork that came with my Neo. I can scan it and e-mail it to you but you will have to wait until tomorrow...the manual is at home and I am aleady at work.
Old Dec 15, 2008 | 09:04 AM
jriggs's Avatar
jriggs
here is a pdf of the install manual for the apexi neo from the apexi-usa website
http://www.apexi-usa.com/pdfInstallation/42.pdf
hope that helps
Old Dec 15, 2008 | 09:45 AM
Bliggity's Avatar
Bliggity
Thanks, now I just the wiring diagram. Once I install it at my house can I drive to the dyno place that is going to adjust it, or will it need to be tuned immediately?
Old Dec 15, 2008 | 09:49 AM
Rock-a-Lex's Avatar
Rock-a-Lex
jriggs - you beat me to it! lol
Bliggity - I left it disconnected for the drive to the dyno shop because a setup of the NEO is ESSENTIAL before you drive the car or you can damage the engine (as per the manual. When they were ready to tune it they simply connected it, set it up and started tuning. GL!
Old Dec 15, 2008 | 10:14 AM
Bliggity's Avatar
Bliggity
What did it run you for the custom harness?
Old Dec 15, 2008 | 11:07 AM
Rock-a-Lex's Avatar
Rock-a-Lex
Around $230/shipped...
Old Dec 19, 2008 | 12:24 AM
evil00017's Avatar
evil00017
where did you get the harness from and where did you mount the neo?
Old Dec 19, 2008 | 07:05 AM
Rock-a-Lex's Avatar
Rock-a-Lex
Visit there website: Boomslang.us. They are EXCELLENT at making custom PnP harnesses for ANY vehicle and for ANY application.
When I was ordering it I was a little weary because they had never made a custom harness for the GS400 with Apexi Neo connectivity. They needed my GS400's pin-out sheet (I obtained from my local library) and a copy of the Apexi Neo's installation manual. I then estimated how much length in feet that I needed; I think it was something like 6' (to play it safe, you can always ziptie the extra).
Less than one week later it was at my door and all is well. Plus, when I sell my car down the road at least I can put everything back to stock without hacked ECU wires.
They are great people to deal with...GL!
Old Dec 20, 2008 | 05:15 PM
GS FONZy's Avatar
GS FONZy
I know what you are talking about SRT, SAFCII and NEO all have different ECU diagrams for installing.
SAFCII
NEO
Old Dec 20, 2008 | 10:23 PM
Bliggity's Avatar
Bliggity
So the NEO only has 5 wires?
Old Dec 21, 2008 | 10:32 PM
GILLEXUS's Avatar
GILLEXUS
Do you have a GS430? The ECU pins are different. See if Boomslang will make you one for the GS430,see if they have done one before.
I had one made by Autosport it cost more I think $280 I could not find any one making one for the 01+ GS430 at the time. I sent Autosport pin locations from the service manual.
I believe the Neo has same connections as the S-AFCII- pwr,grd,knock1 &2,Maf,tps and rpm. The SRT GS430 ECU locations area a good start.
The only difference from SRT's & Apexi was the RPM location. SRT use the signal from the ignition and Apexi uses the signal going to the tachometer.
Attached Thumbnails Apexi NEO wiring diagram help please-srt-wiring-01-gs430.jpg
Old Dec 21, 2008 | 10:37 PM
GILLEXUS's Avatar
GILLEXUS
Here is the Apexi S-AFC II diagram I used for my 01 GS430 when I had it connected. I checked all these locations w/ the service manual to be sure it works.
You can see the 430 has more pin connectors than the GS400.
Attached Thumbnails Apexi NEO wiring diagram help please-sfacii-430-ecu2.jpg
Old Jun 15, 2010 | 08:36 PM
Rich23's Avatar
Rich23
Does any one have the maf sensor schematic diagram for a 2001 gs430 and a 1999 gs 400, somewhat like this for the maf sensor?
Old Jun 16, 2010 | 04:48 AM
GILLEXUS's Avatar
GILLEXUS
Do you mean the wiring for The MAF it self?
