Blitz throttle controller
I just test drove an IS350 with the Tom's version (which is the same), last night.
Basically it feels like Sport Mode, but X10...
For explanation purposes I will describe SP3.
SP3- It is the most responsive setting. The accelerator response is lighting fast..
As soon as you start to press the gas pedal the car is just about jumping or lurching forward..
I actually said "WoW", when I barely touched the gas pedal...
Overall, it gives you a quicker response with less pedal pushing and wait time... on initial launch... or cruising..
It's an interesting little gadget...
- Joe Z
- Joe Z
- Joe Z
- Joe Z
Would you not get the exact same result on a stock 350 just having pushed the pedal further instead of just barely touching it?
Because as near as I can tell all this thing does is lie about how far you pushed the gas to the ECU. (and the higher the setting the bigger the lie it tells)
I would say if anything shortens the response time... (more than a human could do)
Like I mentioned.. Sport mode ON (but X 10)
There is more info in this thread....
https://www.clublexus.com/forums/sho...d.php?t=382027
how much does this gadget go for?
so basically it makes your engine more responsive at the slightest touch, making it feel as if the engine was a bigger and had more low end torque than it really does?
- Joe Z
- Joe Z
