injector question
Old Feb 11, 2008 | 11:26 PM
tommyGS3's Avatar
tommyGS3
Default injector question
well i got my turbo and almost ready to install. i was wondering will this fit?
http://cgi.ebay.com/ebaymotors/PTE-5...spagenameZWDVW
http://cgi.ebay.com/ebaymotors/RC-Fu...spagenameZWDVW
any info would help me alot
and 550cc enough or should i go 650cc
i'll be boosting under 350hp
Old Feb 12, 2008 | 12:42 AM
macd7919's Avatar
macd7919
Well...I noticed your looking at Mk3 injectors. I'm not sure about them but I know in the IS (which should be the same rail as the Gs3) that the Rc injectors I used to use needed to be machined on the lathe to work. A general rule of thumb on injectors for the 2jz is 1cc/1hp, so running 550cc will be plenty for making 350hp. Idk what your doing about fuel management but the further out you get (larger) on injectors the more correction you are going to need to make, again, depending on what fuel management you have there is a limit on how far it can adjust.
Old Feb 12, 2008 | 10:28 AM
GSoup's Avatar
GSoup
CL Folding 10,000
MKIII injectors require a resistor box, they're low impedance.
440cc will do the job since your not boosting over 350hp.
RC Engineering 440cc high impedance saturated fuel injectors.
Model number SL4-440 are direct drop in.
Old Feb 12, 2008 | 11:14 AM
ElitistK's Avatar
ElitistK
SARD rx-7 550cc will also do the trick.
before you slap on those bigger injectors...are you at least getting a 255LPH fuel pump?
Old Feb 12, 2008 | 11:22 PM
tommyGS3's Avatar
tommyGS3
would i still need wire clips?
and i will upgrade the fuel pump too
Gman1jz
Sep 17, 2012 05:40 PM
Toastt
Feb 20, 2011 04:49 PM
That-Guy
Nov 25, 2008 09:48 AM
Dx3
Performance
15
May 12, 2006 02:31 PM
