Bullet (Australia) Supercharger?
Old Feb 12, 2008 | 05:30 PM
  #46
Frankdorn's Avatar
Frankdorn
So add a walbro and high-flow injectors you're saying? Could I get by on 93 octane w/o a significant meltdown risk at 9psi?
Old Feb 12, 2008 | 05:35 PM
  #47
IAGS400's Avatar
IAGS400
Originally Posted by Frankdorn
Maybe a dumb question, but why? Wouldn't the intercooler be inline with the intake piping?
The setup on the web site has the supercharger blowing down into the intake, in order to cool the air you would need to put a water to air intercooler in the intake between the supercharger and the heads, which means you would need to raise up the supercharger to make room for the intercooler.
You could invert the supercharger and then do a conventional air to air intercooler like the RM kit but I don't think there is enough room to go that route.
Old Feb 12, 2008 | 05:37 PM
  #48
IAGS400's Avatar
IAGS400
Add methanol injection to cool down the air and it shouldn't be a problem.
Old Feb 12, 2008 | 05:39 PM
  #49
GS FONZy's Avatar
GS FONZy
From what I was told, no. Unless meth/h2o injected to keep from having detonation problems.
Old Feb 12, 2008 | 05:45 PM
  #50
Frankdorn's Avatar
Frankdorn
I'd rather slice my hood open and lay a bubble over the hole to clear the intercooled SC...I think. What about a thicker headgasket?
Old Feb 12, 2008 | 05:52 PM
  #51
BLAZE's Avatar
BLAZE
Bud, no offense, but if you want to go fi on gs4 you got a lot of homework to dowish I bought a gs3 instead
Old Feb 12, 2008 | 05:53 PM
  #52
IAGS400's Avatar
IAGS400
The IC would need to be about .5 inches thick.
Old Feb 12, 2008 | 05:55 PM
  #53
GS FONZy's Avatar
GS FONZy
what about it you lower your compression. Do you know why you are asking this question?
Old Feb 13, 2008 | 12:36 PM
  #54
Frankdorn's Avatar
Frankdorn
What is it that I'm not seeing? ...that's why I'm asking these questions--they're all out of "How to Supercharge Your 1uz-fe w/ vvti" at Barnes & Noble.
What about it you lower your compression. Do you know why you are asking this question?
Wouldn't lowering the compression help a little with the detonation risk, and getting a steel hg help with durability?
I'm mechanically inclined, but not a car expert, so I'm just feeling out how hard this project would be before pursuing it... A Bullet kit retro doesn't sound impossible with some guidance and a mill...
Old Feb 25, 2008 | 06:31 AM
  #55
Lextreme's Avatar
Lextreme
The 1uzfe from 1989 to 1997 and 1998 to 2000 are different. The manifold WILL NOT work on the GS400. The two engines have different head/manifold angle. Perhaps u should look into the Tundra TRD M90 supercharger. Its a direct bolt on.
Old Feb 25, 2008 | 04:50 PM
  #56
GS FONZy's Avatar
GS FONZy
It will bolt on the post 97 1uzfe? What year Tundra S/C?
Old Feb 25, 2008 | 04:54 PM
  #57
Lextreme's Avatar
Lextreme
97 and 98 are diferent. Bullet will bolt on the 1997 but not 1998. I think Tundra started in 1998.
Old Feb 25, 2008 | 06:01 PM
  #58
GS FONZy's Avatar
GS FONZy
post 97, meaning the 98 model, vvti. I did some searching and came up empty since that SC is no longer available. If you find a used one, the hood will need to be moded to clear the sc. Also, we would need to figure out how to tune it because I doubt the ecu will work on our cars.
Old Feb 29, 2008 | 03:08 AM
  #59
GILLEXUS's Avatar
GILLEXUS
FYI,
Maybe check w/ a few of the SC400 guys, good source of infro. A few of them have done a roots style S/C . I know its not the VVTI motor.
I believe ScottURnot used an Eaton M90 he may have info. on if they make an adapter plate that will allow it to mat up w/98+ intake/manifold.
Just a thought.
https://www.clublexus.com/forums/sho...d.php?t=240378
Old Mar 1, 2008 | 01:52 PM
  #60
Frankdorn's Avatar
Frankdorn
It looks like Richwood Technologies is coming out with a supercharger kit:
----- Original Message -----
To: richwoodtechnologies@bigpond.com
Sent: Sunday, March 02, 2008 3:06 AM
Subject: GS400/430 supercharger?
"Do you make an Eaton M90 supercharger kit for the iuz-fe vvti V8 found in the 2nd gen Lexus GS 400/430?"
Reply:
"Yes we do, it is a fully Integrated supercharger, we will be releasing this shortly. Please check our web-site www.i-charger.com for updates.
Regards
Andrew"
