Swapping 250 tranny into 350?
Old Jan 9, 2008 | 01:43 AM
2slow's Avatar
2slow
Default Swapping 250 tranny into 350?
Is it possible to change the 350 tranny for a manual 6 spd tranny from a 250?
Old Jan 9, 2008 | 01:46 AM
llamaboiz's Avatar
llamaboiz
Err... if your gonna spend that kind money, why not something alittle more tougher? Getrag 6speed, T-56, TKO II... something wayyy better. Might need a custom length drive shaft too reguardless if its a 250 trans.
Knowing you, you'd blow that stock 250 tranny in less than a month Not to mention the drive shaft/axles.
Old Jan 9, 2008 | 02:49 AM
2slow's Avatar
2slow
LOL, i don't know as much information on car trannys and things like that so i would thinking since the car is very similar so i would think it is possible.
I know..but I've died down llamaboiz. Don't worry about anymore threads about my racing. If you do, it'll be in the obituary's section.
Old Jan 9, 2008 | 08:16 AM
Kurtz's Avatar
Kurtz
Other problem is the ECU. The IS350 ECU expects to see an automatic transmission attached to the car.
I know in an F-body for example you can reflash (or physically swap if you don't haver the stuff to flash) the ECU from a manual but that's not an option here since the engine isn't the same either.
Old Jan 11, 2008 | 07:01 AM
Gernby's Avatar
Gernby
Then there's the issue with the manual tranny from the IS250 being a total piece of ****.
Old Jan 11, 2008 | 08:17 AM
linh811's Avatar
linh811
If you like modding, it'd be a lot simpler to trade in for a 335i
Old Jan 11, 2008 | 07:41 PM
carchitect's Avatar
carchitect
Its because it came out of a Tacoma X-runner
Old Jan 11, 2008 | 07:43 PM
carchitect's Avatar
carchitect
Even if you get the gearbox to attech to the engine and drive the rear tires you won't be able to keep the engine ECM happy with that on there.
Old Jan 25, 2008 | 01:45 PM
Wid IS350's Avatar
Wid IS350
Make it 2 while you're at it
Old Jan 27, 2008 | 11:18 AM
Taylor@DP's Avatar
Taylor@DP
Hey dude!!! I like my X-runner
Good thing I bought it for a work truck though, the trans is a far cry from a performance piece.
Old Jan 27, 2008 | 08:58 PM
DEMIK's Avatar
DEMIK
Not worth it tranny can barely hold the weak a%# is250 motor
kinglexus99
Dec 31, 2014 03:44 PM
ReeM
GS - 1st Gen (1993-1997)
Jul 7, 2011 04:41 PM
ShibbySC4
Oct 28, 2010 11:03 AM
g0tpersian
Performance
16
Sep 19, 2008 08:37 PM
unit74
Apr 19, 2006 05:42 PM
