mazzuri super headers
Old Mar 8, 2008 | 06:30 AM
  #256
Gernby's Avatar
Gernby
I fail to see how a set of pipes can "break in" in such a way that the sound will change. It's not like the sound deadening material is changing over a few hundred miles. I think that you are just getting used to the sound.
On a side note, If I were you, I would disable that nag light on the tachometer right away. It's coming on WAY too soon!
Old Mar 8, 2008 | 10:48 AM
  #257
Smooth 1's Avatar
Smooth 1
I think the sound does change as the seals conform. I know that alot of exhaust systems have slight leaks until they heat up and cool down a few times and the seals close up and tighten. I think that's why there is some sound changing as it "breaks" in so to speak.
Old Mar 8, 2008 | 11:55 AM
  #258
CrazyIS's Avatar
CrazyIS
AN ISSUE WITH THE HEADERS. I need some help on.
Twice so far when I am in traffic the check engine light has come on, and a warning that says CHECK VSC. The car goes into some kind of safty mode and I am forced to find a place to pull over.
All I need to due, to recover is turn off the car and turn it back on and I am good to go. Both times it happened I was in traffic coasting between nuetral, 2nd, and 3rd gear.
Should I be worried? What can I do to prevent this?
Old Mar 8, 2008 | 12:15 PM
  #259
Gernby's Avatar
Gernby
Stop by an AutoZone, and ask them to pull the diagnostic codes. It is a free service.
Old Mar 8, 2008 | 12:27 PM
  #260
mazzuri's Avatar
mazzuri
I posted about this on the previous page, to see if any one knows something I don't. At this point I am almost positive it's one of two things.
1. I had the issue when the car was cold, but never in traffic. Jay (the 1st guy to buy a set) so far has 120 miles or so with the header and has not gotten the same warning. So one of the reasons I think this is happening to us CA folk is our cheap gas. It would be more prone to knock and would make sense for me to get it when the car is cold and under load and in traffic when the engine gets hotter. Like I said earlier when i did a full tank of 100 with the header I had no issues at all.
2. It may be a random misfire here and there, due to the A/F being on the lean side in the lower RPMS, if that is the case adding some fuel should take care of it for good.
Working with Toyotas I don't usually see a misfire from a lean mixture, but this engine is very different and with it's very high compression it may be much more sensitive... If I had to pick one, I think it's number 1 that is causing the problem. Since Jay has been filling up 93 and has had no problems.
As far as safety, that is why it goes in to that safe more to protect everything, so a random knock or a misfire will not hurt anything as there are safety measures built in to protect the engine.
2.
Old Mar 8, 2008 | 01:15 PM
  #261
CrazyIS's Avatar
CrazyIS
Danial where did you buy 100 octane around here?
I put octane booster before the second check engine. That didn't work, but let me try the 100 octane fuel.
Old Mar 8, 2008 | 01:42 PM
  #262
mazzuri's Avatar
mazzuri
The only place I know is at the end of the 110 when you are heading to Pasadena. I think it's North. Rigth when the freeway ends there is a gas station on the right. They sell 100 there.
Old Mar 8, 2008 | 02:10 PM
  #263
Gernby's Avatar
Gernby
A can of octane booster probably only increased your tank of 91.0 to probably 91.5.
Old Mar 8, 2008 | 10:57 PM
  #264
teejnut's Avatar
teejnut
http://forum.e46fanatics.com/attachm...0&d=1197319229
from
http://forum.e46fanatics.com/showthr...50100&t=528974
Old Mar 9, 2008 | 06:00 AM
  #265
Gernby's Avatar
Gernby
What is the point of this?
Old Mar 9, 2008 | 09:25 AM
  #266
dat-is350's Avatar
dat-is350
I think hes answering a question for another member about where to get 100 octane gas.
Old Mar 9, 2008 | 10:58 AM
  #267
CrazyIS's Avatar
CrazyIS
Thanks teejay and Danial. I am going to stop there this week and try the 100 octane out and see if thats it.
Old Mar 9, 2008 | 12:01 PM
  #268
teejnut's Avatar
teejnut
100 octane locations in the wonderful CARB state of CA. There use to be a way to search for 100 octane through 76's website but couldn't find it so sent that link instead.
If 100 octane resolves your problem then this makes an interesting mod for CA owners. Let us know how much the 100 octane costs! 91 right now is about $3.75...
Old Mar 9, 2008 | 01:26 PM
  #269
ba-b4's Avatar
ba-b4
lol I don't see how this is really a fix even if 100 octane takes care of the problem. 100 octane must be like 8 bucks a gallon or something. Maybe for a track car or something it's worth considering.
If these are the kind of problems that we can expect then these headers are in no way ready for primetime yet.
Old Mar 9, 2008 | 05:29 PM
  #270
uschardcor's Avatar
uschardcor
well 93 octane seems to be working for the one guy. my question is why wasn't he filling up with 93 in the first place? isn't that the recommended type for our car? only the 350?
i think the sound is fantastic on the 250 from what i hear, hope the 350 isn't all too loud. i'm sure it will be powerful regardless. u go daniel
