Is there a premium coolant? (updated with pics)
Old Nov 21, 2007 | 07:40 AM
kevs98GS4's Avatar
kevs98GS4
Originally Posted by 1SICKLEX
My question is, can you install the thermostat yourself?
YES! Doesn't get to be a much easier DIY than that one! Only two bolts! GL let me know if you need some help!
Old Nov 21, 2007 | 09:18 PM
mikevanle's Avatar
mikevanle
Toyota Red for all my rides, as well as my parent's cars.
Old Nov 21, 2007 | 09:32 PM
TAMR_GUS98's Avatar
TAMR_GUS98
Mike, Please don't put anything other than the toyota red in your Lex. I will send you a gallon of the stuff just to make sure you don't. LMK if your interested.
-Will
Old Nov 26, 2007 | 08:22 AM
LexFather
Guest
Posts: n/a
My stuff should be here today or tomorrow, so can you let me know what to do? Thanks
Old Nov 26, 2007 | 05:04 PM
chuckb's Avatar
chuckb
I use toyota red too.
Old Nov 26, 2007 | 06:36 PM
TAMR_GUS98's Avatar
TAMR_GUS98
Red Toyota Coolant coming your way Mike. I will be PMing you with the details. Consider it a Christmas present.
-Will
Old Nov 27, 2007 | 08:56 AM
LexFather
Guest
Posts: n/a
-Will
Will,
That was really nice of you, I appreciate it.
Old Nov 27, 2007 | 05:33 PM
TAMR_GUS98's Avatar
TAMR_GUS98
Will,
Not a problem. Just don't put that green shiat in your Lex. LOL
-Will
Btw, I did something for OldDog last year for Christmas as well. This is starting to become and unintended tradition. LOL
Old Nov 28, 2007 | 06:16 PM
LexFather
Guest
Posts: n/a
Exclamation
-Will
TRD cap/Thermometer and your present came in today!!!
Should I flush the system (how) and how do I DIY the thermometer? (I searched!!!)
Unless you want to do it Kev?
Thanks!!
Old Nov 28, 2007 | 06:23 PM
Och's Avatar
Och
Thanks!!
Dude, just let the professionals do it. Changing the thermostat is very easy, and if you dont know how to do it, you're not up for the task of flushing your coolant. Not that it's hard, but it requires getting under the car.
Old Nov 28, 2007 | 07:40 PM
TAMR_GUS98's Avatar
TAMR_GUS98
Thanks!!
Glad you got it without any problems.
Can't really flush unless you have a flush machine. How long has the coolant been in there? Drain and fill is all that is needed if its only been about 30k miles. Open the cap and then open the drain in the bottom of the radiator. Look for a clear plastic tube sticking out of the lower engine cover that should give you an idea of where the drain is. Just open it like a fauset in your bathroom. If your up to a bigger challenge jack the car up and remove the lower engine cover. On the sides of the block, there are drains. Like a fauset. Be carefull as this makes a big mess unless you put a hose on the drain spout.
The thermostat should be just 3 nuts and its out. Just make sure you drained the coolant first. And always replace the rubber O-ring.
If you have a 400. Take the engine cover off the top of the intake plenum. On the top of the throttle body housing there should be a fill hole to stick a funnel into. It can be removed with and allen wrench or socket. I believe its a 10mm allen. Just twist the funnel into the hole if you have a plastic funnel. The threads in the hole will help hold the funnel in place. Be carefull, sometimes the funnel works itself loose and falls out. You can put some electrical tape on the funnel if the hole is a little bigger than the funnel. Creates a seal so the coolant doesn't leak out also.
If you have a 430 just fill in the opening where the radiator cap goes. You might get an air bubble stuck in the cooling system. If this happens you can usually hear a girgling noise in the dash when accelerating. Just drive it, let it cool off and refill the reservour. Keep an eye on it. You might have to refill it a few times depending on how much air gets stuck in the system. The air usually gets stuck in the heater core. If you look at the heater hoses, you'll notice it sits higher than the engine making it difficult for the coolant to get to the heater core. This is also why I recommend the funnel in the throttle body filling method.
That should be it.
Good luck Mike.
-Will
Old Feb 16, 2008 | 12:51 PM
LexFather
Guest
Posts: n/a
https://www.clublexus.com/forums/sho...ght=thermostat
Is this site the best or what....
This also came in handy, guy is in GA too....
https://www.clublexus.com/forums/sho...d.php?t=310051
My write-up to come.. Thanks Will and Nuum!
Old Feb 19, 2008 | 06:44 PM
LexFather
Guest
Posts: n/a
The first link is written by my main man Nuum, I COULD NOT find the thermostat anywhere!! I was all under the car looking
CAme back here and SEARCHED and look at what I found.
To contribute, here are pics of the open valve and the OEM therm vs the TRD Racing Therm.
Old Feb 19, 2008 | 06:48 PM
LexFather
Guest
Posts: n/a
Its right behind the front intake...so take that off..Its one bolt, if you can't figure that out, stop, skip the beer, take a shot of 151 Bacardi and cry and just take it to the dealer....lol
I believe it was a 10 mm bolt, you can see I have an extension, as stated before its 3 bolts.
Old Feb 19, 2008 | 07:04 PM
LexFather
Guest
Posts: n/a
Taking it off....
It is off now
This is where the Thermostat lays...the 3 bolts/cover holds it in place. Notice the rubber seal, you NEED to ensure you have this on the new Thermostat
Place a towel under the valve before u take the thermostat out so u don't leak coolant on your belt (and have loud noise coming from it for a few hours, lol)
