what management to use
Old Dec 2, 2007 | 09:07 PM
JeffTsai's Avatar
JeffTsai
Originally Posted by tommyGS3
and one more thing,,,, the maf sensor, how do u run it with turbo??? or do u leave it out????
You put the MAF sensor somewhere in the charge pipe. As long as it's in there you'll be good to go. It's necessary to keep the stock MAF sensor in the air stream for the automatic transmission to function. The transmisson control and shift points are based off the MAF sensor readings.
Originally Posted by exquisit
on all the post that mention a ecu (stand lone, piggy back or otherwise) no one has mentioned a apexi power fc
i was wondering why this is?
any particular reason that no one seems to use one??
Technically you can use any standalone system on this car. Reason being is because there is no application specific standalone system for a 2nd gen GS with the 2jz VVTi engine. Any system you use will require you to build a custom harness or pay someone else to make a plug and play harness for you. As long as the standalone system you are using can control 6 injectors and 6 ignitors...you'll be good to go. The PowerFC is an older system so I think that might be part of the reason why nobody really uses it...also I think Apexi filed for bankruptcy so you probably won't be getting support any more from them.
One other upside about the AEM EMS, you can control your VVTi system thru the AEM's various PWM outputs. You just have to know how to wire it up and tune it. Or if you're sending it to a shop...make sure they know how.
Old Dec 3, 2007 | 01:27 AM
exquisit's Avatar
exquisit
interesting... i'll have to look into apexi being filed for bankrupcy
i'll do a bit more research into aem and other ecu's
thanks!
Old Dec 5, 2007 | 06:09 PM
BurgandyGS's Avatar
BurgandyGS
I bought the HKS F-Con V pro. I too tried to use a piggyback (map-ecu) but there is still some issues: relearning,startup, lean in tip, etc. I spent many hours tuning on a dyno and driving. You need a standalone! Trust me. If your like me, you want it to feel like stock until you step on it. Mine will be installed on next Saturday so look for an update. All the aristo's in Japan are running f-con. There must be a reason and I have never read one bad comment ever.
Old Dec 5, 2007 | 07:03 PM
exquisit's Avatar
exquisit
yea most of the supras (coz not many worked gs or 2nd gen aristos) are using PFC here in aus
my main concern is that the standalones wont have all the functions as a stock computer would, namely how the auto shifts and traction control etc
Old Dec 5, 2007 | 11:30 PM
JeffTsai's Avatar
JeffTsai
Man, you must be ballin! lol. The HKS isn't cheap to buy and you have to have a authorized/certified tuner to tune that system.
Running a standalone on these cars is different than on other cars. On the GS, the factory ecu is so complex and intergrated into the car...it's very difficult to run the car without it. Instead, what people do is run dual ECU's. So the factory ecu still controls transmission, gauge cluster, links with vsc/abs, and whatever else in the car that is multiplexed onto the stock ecu. So basically, you let the factory ecu do what it was meant to do and have a standalone to control the fuel and ignition of the engine strictly.
Old Dec 6, 2007 | 03:51 PM
exquisit's Avatar
exquisit
ahhhh!
i see... so the standalone doesnt truely stand alone!
i was gettin confused but now i understand where you guys r coming from
Old Dec 11, 2007 | 06:00 AM
adamgamz's Avatar
adamgamz
ahhhh!
well it does stand alone in doing the one thing it was designed for, running your motor.
I would not ever again touch a piggyback ECU, I tried for months to screw with mine and it was nothing but one big headache. I have a Haltech E8 going into my car now, running a stand alone is the only way to go with these cars if your going to mod them. You might blow your engine running a piggy back, these cars are constantly changing the fuel curves, I tried everything from wiring a resistor into the coolant temp sensor to keep the car in cold start mode, hooked up a black box to reset the ecu on ignition cut, tried running with no 02 sensors.. nothing works. Pull the ecu out if your going FI... IMO a supercharger is a bad way to go, you can put together a complete turbo kit for under 5 grand.
Old Dec 13, 2007 | 05:59 PM
JPI Racing's Avatar
JPI Racing
Default JPI AEM EMS kit
We are now offering the AEM EMS PNP kit for the GS300 application. The kit include the jumper harness, PNP harness, instruction for install and a start up map. MSRP is $2100.
Here is the picture
JPI Racing
Old Dec 15, 2007 | 10:39 AM
LeXaNoMicS's Avatar
LeXaNoMicS
Hey Jeff,
Or anyone else who nows .Does the haltechx10 throw CEL
Old Dec 15, 2007 | 03:36 PM
adamgamz's Avatar
adamgamz
Originally Posted by LeXaNoMicS
Hey Jeff,
I think any standalone will throw a cell, just ignore it or pop the bulb.
Old Dec 15, 2007 | 04:39 PM
LeXaNoMicS's Avatar
LeXaNoMicS
yea but dont they check for cel's when smog ck
Old Dec 15, 2007 | 04:49 PM
adamgamz's Avatar
adamgamz
Don't know, we don't have inspections here in Florida. I would ask the guys on myis.net
Old Dec 15, 2007 | 05:32 PM
LeXaNoMicS's Avatar
LeXaNoMicS
k coo thanks ..im thinkin i can make any turbo "legal" by adding a hi flow cat to the exhaust system after all i can find some fairly leanient smok ck place
Old Dec 16, 2007 | 07:46 AM
adamgamz's Avatar
adamgamz
I wouldn't think they care about cells as long as you pass emissions.
Old Dec 16, 2007 | 10:32 AM
morris's Avatar
morris
IN the states that I know of, you cannot pass emissions if you have a CEL
