2004 GS ECU Reset
Old Jul 18, 2007 | 07:44 AM
darchard's Avatar
darchard
Question 2004 GS ECU Reset
I posted eariler on this topic but I have a new question. The 04 GS has three "ECU" fuses. I don't want to pull the wrong one to perform the reset. Which one do I need to remove? Thanks in advance.
Dave
Old Jul 18, 2007 | 08:35 AM
JPI Racing's Avatar
JPI Racing
What are you trying to do? Reset the long fuel trim.
JPI
Old Jul 18, 2007 | 09:19 AM
JeffTsai's Avatar
JeffTsai
Just pull the negative battery terminal for 15-20minutes and you should be set.
Old Jul 18, 2007 | 11:05 AM
darchard's Avatar
darchard
Enough said. I'm pulling the negative battery terminal. Thanks!
Old Jul 18, 2007 | 11:31 AM
JPI Racing's Avatar
JPI Racing
The reason I ask if you want to reset just the Fuel trim. Pull connectors the the main ECU plug #1 and 3. Or pull the negative to reset the whole thing.
JPI
Old Jul 18, 2007 | 11:46 AM
darchard's Avatar
darchard
JPI,
I didn't mean to ignore you. My issue is that I bought my 04 GS from a friend with only 25K miles on it. I read that the GS learns the driver’s habits and there is a little hesitation in certain instances that don't feel right. The previous owner and I have counter opposite driving habits. He drove to his office every day no more than 10 miles. I am in my car every day and can put on up to 50K per year. The ECU reset sounded like an easy attempt to remedy the hesitation. I could be wrong and heading in a direction that I should not...who knows.
Old Jul 18, 2007 | 04:24 PM
GSquicksilver's Avatar
GSquicksilver
eventually your car will learn your driving habits, so it's not really necessary to reset the ecu. it'll just take some driving and in time, it'll adjust to your current habits.
Old Jul 20, 2007 | 05:39 AM
darchard's Avatar
darchard
I did the removal of the negative brake terminal and I must say that the pick-up on both the highway and local roads is unbelievable...in a positive way. Great fix for someone who purchased a pre-owned Lexus.
Old Jul 20, 2007 | 06:07 AM
DarKnight's Avatar
DarKnight
Although effective I don't like to reset the ECU by disconnecting the negative battery terminal because it resets everything, like my bloody radio stations, well actually I don't know if it will do that on my aftermarket hu but I'll see.
awesomefar
Jul 12, 2018 10:21 AM
rcgo88
Jun 15, 2012 09:09 AM
lserlohn
RX - 1st Gen (1999-2003)
Jun 9, 2011 06:11 AM
joonsta
Jun 24, 2007 04:37 PM
