Headgasket
How much am I going to be looking at to get a thicker headgasket installed on my GS300? Also what mm would you suggest that I purchase for a higher boost application.
I got the Turbo East head gasket upgrade kit. Comes with a 2MM multi layer steel headgasket(made by Cometic I think) and ARP head studs. It drops the stock 2JZ-GE motor with stock pistons down to a 9:1 compression ratio. It costs $400+20ship for the kit. Then you're looking at $600-1000(depending on labor rates in your area) for a shop to install it. Now you see why I did mine by myself
But...I think I can do it in half the amount of time the second time around. So it's not too bad I guess lol.
So what is involved in the gasket change? Isnt it just to pull the headbolts, scrape the gasket and then bolt the head back on ?
Is there more to it?
I guess I am trying to figure out what is so tough about it?
I was thinking the same thing. I thought I could do it until I heard a shop would charge upwards of 1k to do it.
It's a 6-8 hour job if you know where everything is with all the hidden bolts/lines/connectors and have done it before. My first time doing it took me about 3 whole days lol.
There isn't anything super diffucult about it, it's more just knowing what to do. I have done alot of them so I can pretty much just fly through it. There are some imperative steps to take caution with, (torque values, timing, cam removal/installation etc...) You can do it yourself, downside..if you mess it up you are out alot of time and depending what you screw up, your out a motor.
lol...Jason is funny
I'm sure after all that, it would cost almost as much just for him to take it to a shop...heh. Just wondering how come you've done 30+ of these already? Do you have your own shop or something? I know I wouldn't be doing these on a regular basis unless I was paid GOOD lol.
