Tranny Cooler...
Old May 8, 2007 | 08:50 AM
macd7919's Avatar
macd7919
I use a Hayden personally, Flex-A-Lite is also a good brand. Get something a little larger if you have doubts, it's always better to have a little more cooling than less for the tranny, especially if your going to be running a large stall in it. Your going to love the PI Tc though, HUGE difference off the line
Old May 8, 2007 | 09:20 AM
tmf2004's Avatar
tmf2004
5% Club. Killing it!!!
Thanks I picked up a B&M...
Old May 8, 2007 | 09:41 AM
JPI Racing's Avatar
JPI Racing
We mounted all the trans cooler in front of the condensor.
JPI
Old May 8, 2007 | 09:52 AM
Rock-a-Lex's Avatar
Rock-a-Lex
Thanks again guys...very helpful
Old May 8, 2007 | 11:13 AM
macd7919's Avatar
macd7919
I have mine done the same way as JPI except on the other side. I think mounting it lower down on the condensor is much cleaner looking than running lines all the way to the top wether they are hard lines or not.
Btw- The little plastic mounts work just fine and have held up on every single car I've used them on (over 20). I'm sure JPI can tell you the same thing.
Old May 8, 2007 | 01:22 PM
GSteg's Avatar
GSteg
I have mine mounted where JPI mounted his and I may even have the same cooler as him. I think I got the B&M 70264 if memory serves me right. It's a big cooler. Maybe overkill for my application, but I like it
Old May 8, 2007 | 01:44 PM
tmf2004's Avatar
tmf2004
I think thats the same one i have also.. I got from the classifeids NIB from FuzzyMD.. Should be getting it this week..
Old May 8, 2007 | 01:57 PM
gs-ireland's Avatar
gs-ireland
I just bought a B&M 70264 and plan to install myself soon. The genuine Lexus A/T rad kit here is ~ €2000!!!
JPI,
The Lexus own aftermarket cooler has the hose connectors at the TOP of the rad, you have them installed at the bottom! Probably to avoid air-locks so the cooler will always be 100% full of fluid.
Here is the TSB for the A/T cooler.
File Type: pdf
Old May 8, 2007 | 03:26 PM
JPI Racing's Avatar
JPI Racing
The factory trans cooler is actually built in from the radiator.
JPI
Old May 8, 2007 | 03:51 PM
gs-ireland's Avatar
gs-ireland
Yes I know, there are even pics in the above attachment to show the original connectors built into the main rad.
What I am saying is the Lexus's own retrofit secondary cooler has the plumbing at the top of it, unlike the way you have it mounted.
Old May 8, 2007 | 04:00 PM
benzo555's Avatar
benzo555
Can Any of yall take pics of the in and out lines from the tranny side? Thanks
Would a fuel line be ok as well? I cant find any tranny lines for some reason.
Old May 8, 2007 | 04:03 PM
JeffTsai's Avatar
JeffTsai
Should be ok to use fuel lines. Fuel lines are made to tolerate harsher chemical substances and higher line pressures.
Old May 8, 2007 | 06:41 PM
JPI Racing's Avatar
JPI Racing
There isn't any air pocket or pressure drop if you mount the cooler this way.
JPI
Old May 8, 2007 | 06:43 PM
JPI Racing's Avatar
JPI Racing
Some of the thickness of fuel lines aren't thick enough but it will work. Your local hose store would carry these items.
JPI
Old May 8, 2007 | 07:27 PM
GSteg's Avatar
GSteg
I dont think there will be any air pockets. Have you seen the pressure/flow of the fluid? You'll only induce air into the system if the fluid doesn't flow enough to reach the top portion of the tranny cooler. Even if there was little amount of air in there, the fluid pressure/flow would have pushed the air into the return line
