Tanabe exhaust moves too much!
Old Mar 27, 2007 | 05:26 PM
Galaxy 40's Avatar
Galaxy 40
Default Tanabe exhaust moves too much!
I finally installed my Tanabe exhaust but noticed that it moves too much. I observed this when my friend was driving my car and i was driving his. I also noticed this when I still had my oem exhaust. Do you guys have this problem? any fix for this? Thanks
Old Mar 27, 2007 | 05:33 PM
TLP_IS350's Avatar
TLP_IS350
its suppose to flex. the exhaust hangers r rubber so it will flex. the exhaust will flex to avoid stress on the hanger and whole exhaust system which will prevent bending, cracking, warping, etc. when the exhaust pipes heat up.
Old Mar 27, 2007 | 06:37 PM
Galaxy 40's Avatar
Galaxy 40
I noticed on other cars the exhuast moves but not as much, maybe I should get a new set of rubber hangers?
Old Mar 27, 2007 | 10:36 PM
Supershyguy's Avatar
Supershyguy
if you dont want it to move they can put a harder hanger or weld it with a piece of metal so it doesnt move. personally I wouldnt worry about it too much
Old Mar 28, 2007 | 10:31 AM
euro.r's Avatar
euro.r
i noticed the stock exhaust moves a lot as well. I wouldn't mind some stiffer hangers either.
Old Mar 29, 2007 | 11:04 AM
ngogsr's Avatar
ngogsr
suppose to have play ....check to see if you hooked hangers on correctly
Old Mar 29, 2007 | 01:31 PM
Gernby's Avatar
Gernby
I doubt stiffer hangers would help, since the hangers do more swinging than stretching.
Old Mar 29, 2007 | 01:38 PM
caymandive's Avatar
caymandive
11 Second Club
Maybe you could add some kind substance to the inside of the hangers. Depending on what you think of using this should increase the friction so the hangers don't swing as much. Or maybe you stretched them out when installing the new exhaust. (if that's even possible) I guess I'll find out tomorrow when I install my Tanabe.
Old Mar 29, 2007 | 08:01 PM
Galaxy 40's Avatar
Galaxy 40
Maybe its the WD40 which is causing it to swing too much
Old Mar 29, 2007 | 10:50 PM
Larry96815's Avatar
Larry96815
Since the Tanabe uses the same hangers as the original I would guess the original swings just as much but no one noticed. I really like my Tanabe, just what I wanted.
Aloha
RastaMc
Sep 17, 2018 04:42 PM
JamalGS300
Performance
Nov 9, 2014 07:16 AM
darinmg
Dec 17, 2013 11:59 PM
Raralith
Performance
Aug 30, 2010 01:46 AM
fluxx
Performance
Jun 12, 2008 03:30 PM
