srt intake installation problem!!
Old Jan 29, 2007 | 08:42 PM
I.B.dAt.Fo's Avatar
I.B.dAt.Fo
Default srt intake installation problem!!
i bought a srt intake and it came in today. i was installing the intake and when it was time to install the srt ecu. i compared the picture of the cars ecu from the instructions and it dont match my car. o yea i have a 02 gs300. plzzz help!! im soo lost on wiring the ecu...
Anson
Old Jan 30, 2007 | 12:42 AM
macd7919's Avatar
macd7919
If the Maf fits in the adapter on the intake pipe then you have the right kit but possibly the wrong instructions. The years that the instructions apply to should be listed on the front of the instructions along with the wiring diagrams being labeled. If they are incorrect email Srt and they will fix it for you.
Old Jan 30, 2007 | 01:58 AM
PHML's Avatar
PHML
Master Thread Closer!!
Instruction manula for SRT ecu wiring diagram for GS300 shows both wiring for 98-01 and 02-05 years. YOu must be looking at the wrong diagram.
Pete
Old Jan 30, 2007 | 09:20 PM
I.B.dAt.Fo's Avatar
I.B.dAt.Fo
yea the maf fits and all but its the r-ecu i dont kno how to wire.
theres only 1 diagram in the manuel and it shows a picture of the ecu and my ecu looks nothing like the one in the picture. is there any1 that installed a srt intake on a 02 gs300??
Old Jan 30, 2007 | 09:26 PM
macd7919's Avatar
macd7919
Did you look on the back of the page? Where are you looking on your car for the ecu?
Old Jan 30, 2007 | 11:17 PM
PHML's Avatar
PHML
Here's for 02+ GS300.
Pete
Old Jan 30, 2007 | 11:48 PM
I.B.dAt.Fo's Avatar
I.B.dAt.Fo
Now Thats How My Ecu Looks!!! Thanx A Lot Phml!!!!! Now I Can Continue Installing Intake!!!
Old Jan 31, 2007 | 01:46 PM
I.B.dAt.Fo's Avatar
I.B.dAt.Fo
i have found another problem while installing the r-ecu.... the colors where sensor 1 and 2 and ignition RPM are pointing at are the wrong colors but i found those colors close by where its pointing at. Should i use those colors i found?? or use the wires where the directions are pointing at????
Old Jan 31, 2007 | 04:03 PM
PHML's Avatar
PHML
Are you sure you're looking at it the right way?
Take close-up pics and post up.
Old Jan 31, 2007 | 04:09 PM
macd7919's Avatar
macd7919
Pin location always overrides wire color when installing the ecu. Just MAKE sure you take your time on the install and SOLDER all the wires. Again, make sure you are looking at the ecu the right way before you do anything and then go by pin location.
Old Jan 31, 2007 | 06:12 PM
I.B.dAt.Fo's Avatar
I.B.dAt.Fo
yea im pretty sure im looking at it the right way.
i will get a picture posted in 10mins
Old Jan 31, 2007 | 06:36 PM
I.B.dAt.Fo's Avatar
I.B.dAt.Fo
Default pic of the whole ecu
whole ecu pic
Old Jan 31, 2007 | 06:37 PM
I.B.dAt.Fo's Avatar
I.B.dAt.Fo
Default sensor 2 and ignition rpm
Old Jan 31, 2007 | 06:39 PM
I.B.dAt.Fo's Avatar
I.B.dAt.Fo
Default sensor 1
sensor 1 pic
Old Jan 31, 2007 | 06:42 PM
I.B.dAt.Fo's Avatar
I.B.dAt.Fo
as you can see the colors doesnt match. i think im going to go with macd7919 and connect them to the wire locations. what you guys think??
