Doing a Clutch/Flywheel job: torque spec
Old Jan 2, 2007 | 10:01 AM
garados's Avatar
garados
Default Doing a Clutch/Flywheel job: torque spec
Hello, I'm going to be undertaking a clutch/flywheel swap (94 Supra N/A) on my 2003 IS300. I'm looking for the torque specs for the following:
Flywheel (Fidanza aluminum) to crank
Pressureplate (ACT HDMM) to flywheel
Bellhousing to block
Driveshaft to transmission and differential
Thanks for the help!
Old Mar 26, 2009 | 07:37 PM
Dr. Yellow's Avatar
Dr. Yellow
bump if anyone knows this info
Old Apr 7, 2009 | 07:28 PM
sniper's Avatar
sniper
the pressure plate is only 17-23 pounds, I did 19. I dunno about the rest, making them nice and tightworks just fine, but be sure and use lock tight on the flywheel bolts.
Also, the non-VVTi, or older N/A supra, clutches are different from the IS300 clutch, as the IS300 flywheel is different from non-VVTi. The OEM IS300 clutch has a solid disc because the flywheel has a built in dampener. Just some info.
DrDDay
IS - 1st Gen (2001-2005)
Mar 30, 2017 04:54 PM
Dexter72
Jun 1, 2015 01:22 PM
tokyojack
Performance
Mar 31, 2011 10:09 PM
davyd32
Feb 15, 2010 12:47 PM
soardrft
Sep 28, 2005 04:59 AM
