2jz-gte w/ 6spd swap in mk2 gs
Does anyone have that setup? if yes, I have 3 questions:
1. Is it the non-vvti, or the vvti version of the gte?
2. How does the clutch pedal fit? does it just exist in between the brake and the e-brake pedal?
3. What about the ecu? i heard of running both ecu's at the same time but i'm not clear on that part.
Any help would be appreciated.
1. is what the non vvti or vvti ? There was never a gs with 6spd from the factory with the exception of a few oddities we have heard but have never been substantiated. If you want the getrag 6spd your going to find it in a supra. I believe 97-98's (?) had vvti.
The aristos did have vvti so you can get one of those with the 5spd auto.
2. What would you run two ecus for with one engine ? There are separate ecms in the car for things other than the engine.
