passenger side in the exact same spot as everyone else. I'll let you guys know how it goes with S&S.
WHOA!!!
I think I want to confirm here.
Members with CONFIRMED cracks:
BA
TeeLex
TAMR GUS98
Dr. G
Slowdriver
wow. well, it does suck, but, we are blazing new trails here and it does make the car faster around town for sure. In the tech world, we call it "bleeding edge".
Good luck in the fixes everyone! At least it's something you can plan for and not get stranded by it happening.
BA
TeeLex
TAMR GUS98
Dr. G
Slowdriver
BA
TeeLex
TAMR GUS98
Dr. G
Slowdriver
Originally Posted by BA_GS400
WHOA!!!I think I want to confirm here.
BA
TeeLex
TAMR GUS98
Dr. G
Slowdriver
Wow, that is one list I would rather not be on. Sorry to hear of the troubles guys as we all know the installation process is involved to say the least. Especially the 400 series.
This must really get a few people worried that have these installed.
Anyone know how to tell 1st gen vs 2 gen? I did not get in on the GB but a few months after as I wanted to hear some initial feedback first. For some reason I think I have the 2nd gen unit.
Lee
Someone might correct me on this, but, I don't believe there is any difference between the 1st batch and the 2nd batch. I *think* it's the 3rd batch that would/should have the 'fix'.
Well, I do know that mine does have a different flange weld/ vs the older versions. Just hope I have the newer welds up top as well. Mine is stamped 47.
Here are pics of mine in this post.
https://www.clublexus.com/forums/sho...header+install
Jbrady, do you know if these are the newer improved headers?
Lee
Lee
LOL! Dude, you got me. I'm the one that found that problem so that they could fix it. I forgot about that.
So, you are correct in that a later batch did incorporate that fix, but I gotta stick by my statement for this newer problem with the cracking. Sadly, I was the first guy to find that too, and that was only in September of this year.
Perhaps I'm just bad luck? hahahaaaa
EDIT: I read your old thread. Now I remember reading it some time ago. Excellent stuff. You and I ROCK!! lol.
Lee
Lee, Originally Posted by Pearlpower
Well, I do know that mine does have a different flange weld/ vs the older versions. Just hope I have the newer welds up top as well. Mine is stamped 47.Here are pics of mine in this post.
Lee
Yours are the redesign with the weld on the inside of the 3 bolt flange. However, this change was made to accommodate the protrusion from the catalysts and really does not effect the problem area.
I have a feeling what is happening here is stress related. Many Japanese and domestic factory exhaust systems use a flex somewhere in the exhaust. The V8 Lexus cars do not. They do have a brace at the bottom of the catalysts. I HOPE everyone kept that brace? Anyway, without a flex the components must absorb any twist and expansion. The crack is NOT the weld itself, the crack is in the metal next to the weld. Welding heat tempers the metal making it more brittle next to the weld. I think we are seeing the effects of the engine torquing/twisting/moving coupled with expansion from heat. This is VERY hard to predict. If I am right a flex from the factory or aftermarket may be the true fix here. We shall see.
I think the 2nd batch/version started w/ the weld on the inside of the 3 bolt flange.
Is this correct Jbrady?
I believe mine were a 2nd batch header and mine are welded on the inside.
One thing that is consistent though, all five that have been reported is on the passenger side.
ExploreLead Lap
Called and left a message with Loren yesterday regarding my issue with the cracked right side header. He promptly returned my call today, asked if my car was a daily driver (yes) and obliged to sending a new header out within a week upon which I will be returning the cracked header once the swap is completed at my shop.
Quote:
...engine torque is probably a factor on them all being the same side. (that, and the weld penetration) Due to the direction of crank rotation, the passenger side of the engine will raise under heavy throttle.
(wasn't sure if you or others knew...)
Lots of good information for those who have had this happen and need to know more. Alot of consistencies and failure analysis. Maybe we need to ask the mods if we can make this a sticky. That way we can all be on the same page on this matter. What do you guys think.
-Will
Btw, still patiently waiting to hear from Loren.
-Will
sorry to all the CL members that are dealing with this issue.
does anyone know when the second bash was made? i purchased the S&S headers in the begining of this year. just want to know if i too will have this problem.
Originally Posted by GS FONZy
sorry to all the CL members that are dealing with this issue.does anyone know when the second bash was made? i purchased the S&S headers in the begining of this year. just want to know if i too will have this problem.
I guess you could call and talk to Loren Barnes at S&S Headers. Ask them if they can send you an updated passenger side header or if they can reweld yours if you send it back. Make sure you refer him to this thread. Here is their contact info.
S&S Headers Inc.
6042 N. 53rd Dr.
Glendale, AZ. 85301-7775
623-847-9000
loren@ssheaders.com
Finally got around to calling S&S and talked to a very nice lady named Betty. She said that they are in the process of building more of our headers. They will be sending me a replacement passenger header as they become available. Probabley won't get it untill January, which is understandable, IMO, due to the Holidays. I will post up as things develope. Hope everyone has a Very Merry Christmas and a Prosperous New Year.
-Will
-Will
I started mine up this morning-very cold-and heard a tick from that side of the car. A quick inspection did not reveal much but I will have to take a closer look. If one is shot then I will just pull them both out and be done with it so hopefully it is the troublesome flange gasket instead.
